Salta al contenuto principale
Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement
Cosa ti serve
  1. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement, Back Cover: passo 1, immagine 1 di 1
    • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
  2. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: passo 2, immagine 1 di 1
    • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
  3. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: passo 3, immagine 1 di 1
    • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  4. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: passo 4, immagine 1 di 3 Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: passo 4, immagine 2 di 3 Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: passo 4, immagine 3 di 3
    • Separate the front and back casing using the spudger.
    • Gently pull apart the two casings.
    • Pull the back casing away from the camera.
  5. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement, Lens Filter Set: passo 5, immagine 1 di 2 Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement, Lens Filter Set: passo 5, immagine 2 di 2
    • Remove electrowind strip from font cover.
    • The front cover does not have to be separated from the device for this step or the next ones.
  6. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: passo 6, immagine 1 di 1
    • Remove lens data cable by gently pulling it out.
  7. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: passo 7, immagine 1 di 1
    • Remove lens filter.
    • There are multiple square pieces, so be sure to remove them all.
Conclusione
Sarah Looper
Membro da: 03/11/13
100 Reputazione
7 Guide realizzate
Clemson, Team 13-4, Benson Spring 2013 Membro di Clemson, Team 13-4, Benson Spring 2013
CLEM-BENSON-S13S13G4
2 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 799
