Introduzione
The lens filter set is responsible for the correct color filtering of the pictures taken. To get to the filter set, remove the electrowind tape and remove the screws holding the lens filter set in place.
Remove the screws from the bottom of the camera using the tri-wing screwdriver.
  • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
Aggiungi Commento
Remove screws from charger side of camera using the Phillips 00 screwdriver.
  • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
Aggiungi Commento
Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
Aggiungi Commento
Separate the front and back casing using the spudger. Gently pull apart the two casings. Pull the back casing away from the camera.
  • Separate the front and back casing using the spudger.
  • Gently pull apart the two casings.
  • Pull the back casing away from the camera.
Aggiungi Commento
Remove electrowind strip from font cover. The front cover does not have to be separated from the device for this step or the next ones.
  • Remove electrowind strip from font cover.
    • The front cover does not have to be separated from the device for this step or the next ones.
Aggiungi Commento
Remove lens data cable by gently pulling it out.
  • Remove lens data cable by gently pulling it out.
Aggiungi Commento
Remove lens filter.
  • Remove lens filter.
    • There are multiple square pieces, so be sure to remove them all.
Aggiungi Commento
Conclusione
Sarah Looper
Membro da: 11/03/2013
76 Reputazione
7 Guide realizzate
Clemson, Team 13-4, Benson Spring 2013 Membro di Clemson, Team 13-4, Benson Spring 2013
CLEM-BENSON-S13S13G4
2 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 456
