Salta al contenuto principale
Fujifilm Finepix F10 6.3 MP Flash Battery Replacement
Cosa ti serve
  1. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement, Back Cover: passo 1, immagine 1 di 1
    • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
  2. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: passo 2, immagine 1 di 1
    • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
  3. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: passo 3, immagine 1 di 1
    • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  4. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: passo 4, immagine 1 di 3 Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: passo 4, immagine 2 di 3 Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: passo 4, immagine 3 di 3
    • Separate the front and back casing using the spudger.
    • Gently pull apart the two casings.
    • Pull the back casing away from the camera.
  5. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement, Front cover: passo 5, immagine 1 di 1
    • Remove screws from motherboard using the Phillips 00 screwdriver.
    • Two 2.5 mm widehead Phillips screws
    • One 3.3 mm #00 Phillips screws
    • Three 2.5 mm #00 Phillips screws (black screws)
  6. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: passo 6, immagine 1 di 1
    • Rotate the front cover clockwise onto its side and remove the single screw on the side using a Phillips 00 screwdriver.
    • Remove 3.3 mm #00 Phillips screw from the side of the front screen.
  7. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: passo 7, immagine 1 di 2 Fujifilm Finepix F10 6.3 MP Flash Battery Replacement: passo 7, immagine 2 di 2
    • Firmly grasp both the motherboard and front cover. Slowly pull the front cover away from the motherboard.
    • Do not be alarmed if it takes substantial pressure to separate the two.
  8. Fujifilm Finepix F10 6.3 MP Flash Battery Replacement, Flash Battery: passo 8, immagine 1 di 3 Fujifilm Finepix F10 6.3 MP Flash Battery Replacement, Flash Battery: passo 8, immagine 2 di 3 Fujifilm Finepix F10 6.3 MP Flash Battery Replacement, Flash Battery: passo 8, immagine 3 di 3
    • Gently remove battery from casing.
Conclusione
Sarah Looper
Membro da: 03/11/13
100 Reputazione
7 Guide realizzate
Clemson, Team 13-4, Benson Spring 2013 Membro di Clemson, Team 13-4, Benson Spring 2013
CLEM-BENSON-S13S13G4
2 Membri
16 Guide realizzate
Un commento
What is the battery number so you can have a replacement ready?
attic77 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 20
Tutti i Tempi: 694
