Salta al contenuto principale
Fujifilm FinePix Z5 LCD Screen Replacement
Cosa ti serve
  1. Fujifilm FinePix Z5 LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 3 Fujifilm FinePix Z5 LCD Screen Replacement, LCD Screen: passo 1, immagine 2 di 3 Fujifilm FinePix Z5 LCD Screen Replacement, LCD Screen: passo 1, immagine 3 di 3
    • Remove the two screws on the right side of the camera and the two screws on the left side.
    • Use a small #00 Phillips flat head screwdriver.
    • Keep all the screws in a container and the two different types separate.
  2. Fujifilm FinePix Z5 LCD Screen Replacement: passo 2, immagine 1 di 2 Fujifilm FinePix Z5 LCD Screen Replacement: passo 2, immagine 2 di 2
    • Remove the three screws from the bottom of the camera.
    • You need a three-prong screw driver for two of the three screws; keep these screws separate.
  3. Fujifilm FinePix Z5 LCD Screen Replacement: passo 3, immagine 1 di 3 Fujifilm FinePix Z5 LCD Screen Replacement: passo 3, immagine 2 di 3 Fujifilm FinePix Z5 LCD Screen Replacement: passo 3, immagine 3 di 3
    • Remove the back by carefully flipping it open to the right side.
    • There will be a ribbon cable attaching the front panel to the motherboard, be sure not to tear this.
  4. Fujifilm FinePix Z5 LCD Screen Replacement: passo 4, immagine 1 di 2 Fujifilm FinePix Z5 LCD Screen Replacement: passo 4, immagine 2 di 2
    • Pull the LCD screen to the left slightly, lift it and flip it open to the right.
    • There is also a ribbon cable attaching the LCD screen to the motherboard, be careful not to tear it.
  5. Fujifilm FinePix Z5 LCD Screen Replacement: passo 5, immagine 1 di 2 Fujifilm FinePix Z5 LCD Screen Replacement: passo 5, immagine 2 di 2
    • Using a small flat head screw driver, flip open the black lever to release the ribbon cable.
    • Gently slide the cable out of the lock; the LCD screen is now free to be removed.
  6. Fujifilm FinePix Z5 LCD Screen Replacement: passo 6, immagine 1 di 1
    • Using your index finger, guide the cable of the new screen into place. Lock it in by pushing the black lever back down.
Conclusione
Kyle Kaczmar
Membro da: 02/10/12
14 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 945
