Introduzione
This guide will enable the user to replace the back panel buttons in the FujiFilm FinePix XP70.
Strumenti
Parti
Nessuna parte richiesta.
Power off the camera.
Push down on the center button and turn the dial on the side counterclockwise to open the battery compartment.
Pull the orange tab towards the hinge to release the battery.
Pry the black button plate off using a plastic opening tool.
Pull the three buttons out.
Remove one Phillips screw with a Phillips head 0 screwdriver
Remove one hex head screw with a hex 1.3 screwdriver bit.
Unscrew two 4.0mm long hex head screws with a hex 1.3 screwdriver bit.
Unscrew five 4.0mm screws with a Phillips head 0 screwdriver
Pry the black bottom plate off using a plastic opening tool.
Pry the front plate off using a plastic opening tool.
Lift off the front plate.
Pry the back plate off with a plastic opening tool
Pry the two latches off using a spudger.
Pry the remaining latches with a plastic opening tool.
Pull the two halves apart.
Unscrew seven 4.0 mm screws with a Phillips 00 screwdriver.
Unscrew four 3.0 mm screws with a Phillips 00 screwdriver..
Lift of the metal panel using a plastic opening tool.
Remove the desired button(s).
