Introduzione
If the lens of your camera has stopped moving in and out of the camera body, it's likely that the gears inside are out or alignment or are broken. This guide will show you how to fix that.
Unscrew the six 3.5mm Philips head from the outer casing. Unscrew the six 3.5mm Philips head from the outer casing. Unscrew the six 3.5mm Philips head from the outer casing.
  • Unscrew the six 3.5mm Philips head from the outer casing.
Aggiungi Commento
Open the battery chamber and remove the battery. Pry the front half of the casing from the camera. Be careful that the sensor cover—the small piece of translucent plastic—doesn't fall out of place. Return it to its original location if it does.
  • Open the battery chamber and remove the battery.
  • Pry the front half of the casing from the camera.
  • Be careful that the sensor cover—the small piece of translucent plastic—doesn't fall out of place. Return it to its original location if it does.
Aggiungi Commento
Pry the back half of the casing from the camera. Be careful when maneuvering the camera without the casing on as the LCD screen is not fastened to anything.
  • Pry the back half of the casing from the camera.
  • Be careful when maneuvering the camera without the casing on as the LCD screen is not fastened to anything.
Aggiungi Commento
Lift the LCD screen out of the camera. There is a tab that keeps in place the ribbon that attaches the screen and motherboard. Lift this up using the spudger and disconnect the screen from the motherboard. There is a tab that keeps in place the ribbon that attaches the screen and motherboard. Lift this up using the spudger and disconnect the screen from the motherboard.
  • Lift the LCD screen out of the camera.
  • There is a tab that keeps in place the ribbon that attaches the screen and motherboard. Lift this up using the spudger and disconnect the screen from the motherboard.
Aggiungi Commento
Unscrew the 3.5 mm Phillips head screw from the corner of the camera.
  • Unscrew the 3.5 mm Phillips head screw from the corner of the camera.
Aggiungi Commento
Pry the center casing off the camera. This is best done by separating the top and side sections individually. Pry the center casing off the camera. This is best done by separating the top and side sections individually. Pry the center casing off the camera. This is best done by separating the top and side sections individually.
  • Pry the center casing off the camera. This is best done by separating the top and side sections individually.
Aggiungi Commento
Unscrew the two 3.5 mm Phillips head screws in the metal plate. Unscrew the two 3.5 mm Phillips head screws in the metal plate. Unscrew the two 3.5 mm Phillips head screws in the metal plate.
  • Unscrew the two 3.5 mm Phillips head screws in the metal plate.
Aggiungi Commento
Pry the metal plate out using the spudger. Pry the metal plate out using the spudger.
  • Pry the metal plate out using the spudger.
Aggiungi Commento
Peel back the strip of black tape to reveal a red and black wire. Detach the orange ribbon by gently pulling on it. Detach the golden ribbon by gently lifting it with the spudger.
  • Peel back the strip of black tape to reveal a red and black wire.
  • Detach the orange ribbon by gently pulling on it.
  • Detach the golden ribbon by gently lifting it with the spudger.
Aggiungi Commento
The lens should now be free to simply be pushed out of its socket. The black and red wires that were exposed previously may be in the way of removing the lens and may break. If they do, you will need to solder these wires back into place upon reassembly.
  • The lens should now be free to simply be pushed out of its socket.
  • The black and red wires that were exposed previously may be in the way of removing the lens and may break. If they do, you will need to solder these wires back into place upon reassembly.
Aggiungi Commento
Unscrew the four 3.5 mm Phillips head screws.
  • Unscrew the four 3.5 mm Phillips head screws.
Aggiungi Commento
Slide the section with the rectangular plastic frame to the side. You'll find that a spring attaches it to the rest of the lens casing.
  • Slide the section with the rectangular plastic frame to the side. You'll find that a spring attaches it to the rest of the lens casing.
  • You can disconnect the frame section from the spring. Do so, and set both so that they're out of the way.
Aggiungi Commento
The white gear and the black gear closest to the round section of the lens unit are the ones most responsible for the lens's movement. Using tweezers, you can adjust and replace these gears as needed. The white gear should be flush with the rest of the unit while the black gear should occupy the entirety of its cavity. Using tweezers, you can adjust and replace these gears as needed. The white gear should be flush with the rest of the unit while the black gear should occupy the entirety of its cavity.
  • The white gear and the black gear closest to the round section of the lens unit are the ones most responsible for the lens's movement.
  • Using tweezers, you can adjust and replace these gears as needed. The white gear should be flush with the rest of the unit while the black gear should occupy the entirety of its cavity.
Aggiungi Commento
Conclusione
Brian Lasher
Membro da: 16/01/2015
313 Reputazione
3 Guide realizzate
USF Tampa, Team 19-3, Blackwell Winter 2015 Membro di USF Tampa, Team 19-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G3
4 Membri
5 Guide realizzate
where can i get these gear’s? my camera is not opening its shutter, kindly let me know.
prabhu mandhar - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 432
