Introduzione
This guide will instruct camera owners how to take off the outer casing and how to access the red, rubber power button. Once you access the button, you can remove it and replace the button with a new one.
Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
  • Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
Aggiungi Commento
Locate the battery door.
  • Locate the battery door.
Aggiungi Commento
Locate the latch on the battery door marked by the word "BATT." Use your finger to pry it open.
  • Locate the latch on the battery door marked by the word "BATT." Use your finger to pry it open.
Aggiungi Commento
Remove the battery from the camera by pulling the battery door outwards.
  • Remove the battery from the camera by pulling the battery door outwards.
Aggiungi Commento
Locate and remove three black 3.80mm screws on the back of the camera with the Phillips #00 screwdriver.
  • Locate and remove three black 3.80mm screws on the back of the camera with the Phillips #00 screwdriver.
Aggiungi Commento
Locate and remove the 6.4mm screws located on either side of the camera with a Phillips #00 screwdriver. Locate and remove the 6.4mm screws located on either side of the camera with a Phillips #00 screwdriver.
  • Locate and remove the 6.4mm screws located on either side of the camera with a Phillips #00 screwdriver.
Aggiungi Commento
Locate the film door latch located on the side of the camera.
  • Locate the film door latch located on the side of the camera.
  • Insert the spudger under the latch.
  • Caution: Be careful during the following step in order to not break any parts within the camera. Prying the latch in any other direction than perpendicular may result in broken parts.
  • Pry the latch upward, applying force perpendicular to the camera.
Aggiungi Commento
Insert the flat edge of the spudger between the gold front casing and the black back casing.
  • Insert the flat edge of the spudger between the gold front casing and the black back casing.
  • Pry the spudger upward until the black back casing snaps out and is dislodged on that edge of the camera.
Aggiungi Commento
Squeeze the camera by placing a thumb on the tab marked CE.
  • Squeeze the camera by placing a thumb on the tab marked CE.
  • Pull the back half of the camera firmly away from the camera body.
Aggiungi Commento
Locate and remove the 3.80mm screw inside the film compartment with the Phillips #00 screwdriver.
  • Locate and remove the 3.80mm screw inside the film compartment with the Phillips #00 screwdriver.
Aggiungi Commento
Pull the front cover off of the camera by lifting the tripod tab over the tripod hole. Pull the front cover off of the camera by lifting the tripod tab over the tripod hole.
  • Pull the front cover off of the camera by lifting the tripod tab over the tripod hole.
Aggiungi Commento
Look on the inside of the black back casing.
  • Look on the inside of the black back casing.
  • Locate the red, rubber power button.
Aggiungi Commento
Using the tweezers, grab the red, rubber power button and pull it off the casing.
  • Using the tweezers, grab the red, rubber power button and pull it off the casing.
  • Discard the faulty power button.
  • Grab the new power button with the tweezers.
  • Put the power button into place by placing it where the old button was.
Aggiungi Commento
Conclusione
To reassemble your device, follow the instructions from the "Disassembling Fujifilm Endeavor 100ix Outer Casing" guide in reverse order.
Eric Nicolai
Membro da: 10/01/2011
679 Reputazione
6 Guide realizzate
Cal Poly, Team 13-5, Forte Winter 2011 Membro di Cal Poly, Team 13-5, Forte Winter 2011
CPSU-FORTE-W11S13G5
5 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,519
