Remove the batteries from the camera to prevent danger of electric shock.
  • Remove the batteries from the camera to prevent danger of electric shock.
Aggiungi Commento
Locate all five screws on the camera. Then proceed to remove all the screws. Locate all five screws on the camera. Then proceed to remove all the screws. Locate all five screws on the camera. Then proceed to remove all the screws.
  • Locate all five screws on the camera. Then proceed to remove all the screws.
Aggiungi Commento
Beware, if your screwdriver does not fit properly, you may damage the screws' heads.
  • Beware, if your screwdriver does not fit properly, you may damage the screws' heads.
  • If your screwdriver does not fit, or you do not have the proper one, you can use a hot glue gun to fix the screwdriver to the head of the screw. Wait for it to harden slightly, and then try to remove the screws.
Aggiungi Commento
Remove outer case.  Pull the back away from the main body of the camera. Remove outer case.  Pull the back away from the main body of the camera.
  • Remove outer case. Pull the back away from the main body of the camera.
Aggiungi Commento
Locate the LCD screen and anchoring screw.
  • Locate the LCD screen and anchoring screw.
  • Remove screw.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Carefully pull the LCD screen away from the board it is connected to.
  • Carefully pull the LCD screen away from the board it is connected to.
Aggiungi Commento
Push both blue switches away from the holding device to unleach lcd ribbon.
  • Push both blue switches away from the holding device to unleach lcd ribbon.
  • Be careful when removing ribbon. If you damage it, you will need to replace it as well.
Aggiungi Commento
Carefully detach the ribbon from where it was connected by the blue pins.
  • Carefully detach the ribbon from where it was connected by the blue pins.
Aggiungi Commento
Now that everything has been disconnected from the board, remove LCD screen.
  • Now that everything has been disconnected from the board, remove LCD screen.
Aggiungi Commento
Remove the two screws holding the circuit board down.
  • Remove the two screws holding the circuit board down.
Aggiungi Commento
Remove black sticky tape from circuit board and camera case. Remove black sticky tape from circuit board and camera case.
  • Remove black sticky tape from circuit board and camera case.
Aggiungi Commento
Gently pull the circuit board away from the front side of the camera. Be careful when removing assembly as to not break any solder leads or damage lens assembly.
  • Gently pull the circuit board away from the front side of the camera.
  • Be careful when removing assembly as to not break any solder leads or damage lens assembly.
Aggiungi Commento
Remove the logic board by pulling straight away from assembly. Remove the logic board by pulling straight away from assembly.
  • Remove the logic board by pulling straight away from assembly.
Aggiungi Commento
Locate the flash unit of the camera.  It includes the camera's flash and a capacitor.
  • Locate the flash unit of the camera. It includes the camera's flash and a capacitor.
Aggiungi Commento
Unsolder the flash unit at it's three points. Be careful not to damage the circuit board or surrounding parts with the solder iron.
  • Unsolder the flash unit at it's three points.
  • Be careful not to damage the circuit board or surrounding parts with the solder iron.
Aggiungi Commento
Conclusione
Cody
Membro da: 18/04/2010
47 Reputazione
4 Guide realizzate
Cal Poly, Team 7-11, Maness Spring 2010 Membro di Cal Poly, Team 7-11, Maness Spring 2010
CPSU-MANESS-S10S7G11
3 Membri
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 3,614
