Introduzione
We will start by removing the wheel and removing any debris that may be obstructing motion, and then reattach the wheel to the axle of the chair.
Familiarize yourself with the tools required for this guide by reading through the Free Wheelchair Mission Tools Maintenance Guide.
Parti
Nessuna parte richiesta.
Use the socket head of the 19mm wrench to unscrew the nut that connects the castor wheel’s fork to the steel frame Remove the wheel from the small steel frame
  • Use the socket head of the 19mm wrench to unscrew the nut that connects the castor wheel’s fork to the steel frame
  • Remove the wheel from the small steel frame
Aggiungi Commento
Hold the bolt that connects the wheel to the fork with pliers This keeps the bolt through the wheel from rotating Use the socket head of the 10 mm wrench in your other hand to remove the nut on the other end of the bolt
  • Hold the bolt that connects the wheel to the fork with pliers
    • This keeps the bolt through the wheel from rotating
  • Use the socket head of the 10 mm wrench in your other hand to remove the nut on the other end of the bolt
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Flip wheel over and remove the bolt Remove the castor wheel Remove the castor wheel
  • Flip wheel over and remove the bolt
  • Remove the castor wheel
Aggiungi Commento
Check for and remove any debris from the wheel or wheel axle that may be obstructing motion of the wheel
  • Check for and remove any debris from the wheel or wheel axle that may be obstructing motion of the wheel
Aggiungi Commento
Conclusione
Alyssa Chaney
Membro da: 22/04/2013
49 Reputazione
1 Guida realizzata
Cal Poly, Team 14-7, Maness Spring 2013 Membro di Cal Poly, Team 14-7, Maness Spring 2013
CPSU-MANESS-S13S14G7
5 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 976
