Introduzione
This guide will explain and show how to replace a charging terminal that has stopped working. Replacing it requires the use of a soldering iron and the Spudger. This is a fairly easy replacement guide and should only take around fifteen minutes.
To open up the casing, you will need to unscrew the four Phillips #0 15mm screws which are accessible from the back.
  • To open up the casing, you will need to unscrew the four Phillips #0 15mm screws which are accessible from the back.
Aggiungi Commento
Gently separate the two halves of the casing.
  • Gently separate the two halves of the casing.
Aggiungi Commento
Disconnect the battery from the motherboard by lifting up on the white plastic tab on the top of the connection.
  • Disconnect the battery from the motherboard by lifting up on the white plastic tab on the top of the connection.
  • Gently pull the cord out by the white plastic adapter. Do not pull from the red and black cord.
Aggiungi Commento
Unscrew the Phillips four #0 15mm screws to free the motherboard from the casing.
  • Unscrew the Phillips four #0 15mm screws to free the motherboard from the casing.
Aggiungi Commento
Slowly pull the motherboard out of the casing. Make sure the loose battery wire doesn't get snagged.
  • Slowly pull the motherboard out of the casing. Make sure the loose battery wire doesn't get snagged.
Aggiungi Commento
Use caution when using a soldering iron, the tip will be very hot.
  • Use caution when using a soldering iron, the tip will be very hot.
  • Locate the charging terminal's three prong connectors on the back of the motherboard.
Aggiungi Commento
Start melting the solder on each prong connector individually with the soldering iron.
  • Start melting the solder on each prong connector individually with the soldering iron.
Aggiungi Commento
Use the flat end of the spudger to pry the charging terminal away from the motherboard.
  • Use the flat end of the spudger to pry the charging terminal away from the motherboard.
Aggiungi Commento
Conclusione
David
Membro da: 23/09/2014
115 Reputazione
1 Guida realizzata
USF Tampa, Team 12-5, Blackwell Fall 2014 Membro di USF Tampa, Team 12-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G5
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 267
