Introduzione
This guide will show you how to replace the camera lens of your Flip Video.
Parti
Nessuna parte richiesta.
Turn off the device and take the batteries out. Remove metal sticker under the LCD screen with a spudger.
  • Turn off the device and take the batteries out.
  • Remove metal sticker under the LCD screen with a spudger.
    • This may require a large force to pry off the glued sticker.
Aggiungi Commento
Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
  • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
Aggiungi Commento
Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell. Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
  • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
Aggiungi Commento
Open battery door. This can be done by gently depressing and sliding the battery down downward.
  • Open battery door. This can be done by gently depressing and sliding the battery down downward.
Aggiungi Commento
Use the spudger to separate outer shells.
  • Use the spudger to separate outer shells.
    • The spudger must be inserted between the shell halves to pry the edges apart.
    • Slowly work around the outside to separate the halves.
Aggiungi Commento
Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
  • Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
Aggiungi Commento
Slowly lift the left side of the circuit board.
  • Slowly lift the left side of the circuit board.
    • Do not attempt to remove the circuit board completely yet. It is still connected to the device.
Aggiungi Commento
Disconnect the USB port cable from the back side of the circuit board.
  • Disconnect the USB port cable from the back side of the circuit board.
Aggiungi Commento
Slide out the battery contacts.
  • Slide out the battery contacts.
    • Battery contacts
    • Slot where battery contacts were located
Aggiungi Commento
With the LCD screen facing away from you, remove the 2 bronze 3 mm screws securing the LCD using the #00 Phillips screwdriver.
  • With the LCD screen facing away from you, remove the 2 bronze 3 mm screws securing the LCD using the #00 Phillips screwdriver.
Aggiungi Commento
Flip over the circuit board and unlock the two black tabs on the ribbon connector by sliding them upwards.
  • Flip over the circuit board and unlock the two black tabs on the ribbon connector by sliding them upwards.
Aggiungi Commento
Gently pull out ribbon cable.
  • Gently pull out ribbon cable.
    • If the ribbon cable does not come out easily you may not have fully unlocked the ribbon cable connector in the previous step.
  • The LCD screen is now removed and can be replaced.
Aggiungi Commento
Flip over circuit board so the ribbon connector is facing up. Remove the 2 stainless steel 3mm screws securing the lens to circuit board with the #00 Phillips screwdriver.
  • Flip over circuit board so the ribbon connector is facing up.
  • Remove the 2 stainless steel 3mm screws securing the lens to circuit board with the #00 Phillips screwdriver.
  • The lens can now be removed and replaced.
Aggiungi Commento
Conclusione
Elizabeth
Membro da: 15/04/2010
100 Reputazione
6 Guide realizzate
Cal Poly, Team 26-21, Regan Spring 2010 Membro di Cal Poly, Team 26-21, Regan Spring 2010
CPSU-REGAN-S10S26G21
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 4,318
