Salta al contenuto principale
Flip Video Directional button replacement or cleaning
Cosa ti serve
  1. Flip Video Directional button replacement or cleaning, Outer Shell: passo 1, immagine 1 di 2 Flip Video Directional button replacement or cleaning, Outer Shell: passo 1, immagine 2 di 2
    • Turn off the device and take the batteries out.
    • Remove metal sticker under the LCD screen with a spudger.
    • This may require a large force to pry off the glued sticker.
  2. Flip Video Directional button replacement or cleaning: passo 2, immagine 1 di 1
    • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
  3. Flip Video Directional button replacement or cleaning: passo 3, immagine 1 di 2 Flip Video Directional button replacement or cleaning: passo 3, immagine 2 di 2
    • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
  4. Flip Video Directional button replacement or cleaning: passo 4, immagine 1 di 1
    • Open battery door. This can be done by gently depressing and sliding the battery down downward.
  5. Flip Video Directional button replacement or cleaning: passo 5, immagine 1 di 1
    • Use the spudger to separate outer shells.
    • The spudger must be inserted between the shell halves to pry the edges apart.
    • Slowly work around the outside to separate the halves.
  6. Flip Video Directional button replacement or cleaning, Flip Video Directional button replacement or cleaning: passo 6, immagine 1 di 1
    • Remove the silicone directional pad insert from the front outer shell.
    • Clean the buttons with soapy water before reassembling the device.
    • Make sure it is completely dry before placing back into the device.
Conclusione
Elizabeth
Membro da: 04/15/10
100 Reputazione
6 Guide realizzate
Cal Poly, Team 26-21, Regan Spring 2010 Membro di Cal Poly, Team 26-21, Regan Spring 2010
CPSU-REGAN-S10S26G21
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,941
