Salta al contenuto principale
Fitbit Alta HR Battery Replacement
Cosa ti serve
  1. Fitbit Alta HR Battery Replacement, Remove straps: passo 1, immagine 1 di 2 Fitbit Alta HR Battery Replacement, Remove straps: passo 1, immagine 2 di 2
    • Push in the clip and slide off the strap from each side.
    Chiedi a FixBot
    Aggiungi Commento
  2. Fitbit Alta HR Battery Replacement, Remove front cover: passo 2, immagine 1 di 1
    • Use a spudger to remove the front cover.
    Chiedi a FixBot
    Aggiungi Commento
  3. Fitbit Alta HR Battery Replacement, Lift display: passo 3, immagine 1 di 1
    • Use a spudger to lift the display.
    Chiedi a FixBot
    Aggiungi Commento
  4. Fitbit Alta HR Battery Replacement, Disconnect heart rate monitor: passo 4, immagine 1 di 1
    • Use a spudger to disconnect the cable that connects the heart rate monitor to the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  5. Fitbit Alta HR Battery Replacement, Remove screws from motherboard: passo 5, immagine 1 di 1
    • Use a hex 0.7 screwdriver to remove the screws from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  6. Fitbit Alta HR Battery Replacement, Lift motherboard: passo 6, immagine 1 di 2 Fitbit Alta HR Battery Replacement, Lift motherboard: passo 6, immagine 2 di 2
    • Use a spudger to lift the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  7. Fitbit Alta HR Battery Replacement, Lift battery and remove innards: passo 7, immagine 1 di 1
    • Use a spudger to lift the battery.
    • When the battery is lifted, the connected components (display, motherboard, battery) will come out.
    Chiedi a FixBot
    Aggiungi Commento
    • Use a soldering iron to desolder the two battery contacts from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
    • Ensure positive and negative wires are in the correct positions. There are + and – signs on the motherboard. Red is positive. Black is negative.
    • Use a soldering iron and lead-free solder to solder the new battery to the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Wendy Sato
Membro da: 11/12/16
259 Reputazione
Una guida realizzata
1Commento della guida
No work no on
deepakkumar8529575607 - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 7
Ultimi 30 giorni: 52
Tutti i Tempi: 3,472
