Introduzione
The transformer takes an input voltage and outputs a different voltage. Without the transformer, the device would receive improper voltages, causing the device to malfunction.
Cosa ti serve
Use a Phillips #0 screwdriver to remove the four 21.7mm screws holding the back panel to the frame.
There will be two black wires connecting the top mounting bracket to the reverb box at the bottom of the unit. Label the wires to prevent crossing upon re-installation, then unplug the wires from the reverb box.
Locate the transformer on the metal mounting bracket and be sure that it looks the same as the replacement that you plan on installing.
The new transformer will have wire leads that need to be spliced with the cut wires from the board and power switch. If you are unfamiliar with this process, here are the fundamentals of how to splice cut wires together.
Altre 2 persone hanno completato questa guida.
3 Commenti
Hello Mr Figueira,
my name is Ben and the transformer of my Frontman 15R is defintely broken. I was able to remove the old one without even thinking about how hard it is to get a new one. Would you recommend buying it straight of Fender or could i try another one with the same output current?
How to test my "Removed" transformer?
TRON,
