Introduzione
If the fuse is blown, the amp will not turn on and a new fuse need to be installed.
Parti
Nessuna parte richiesta.
Be sure to unplug the device before proceeding. Insert any tool with a small, flat end (such as a spudger, flathead screwdriver or plastic opening tool) into the groove in the bottom of the power input and wedge the plastic slot out from the amp. There will be two compartments (one enclosed, one exposed) each containing a fuse.  The exposed fuse is the active fuse and the enclosed one is a spare.
  • Be sure to unplug the device before proceeding.
  • Insert any tool with a small, flat end (such as a spudger, flathead screwdriver or plastic opening tool) into the groove in the bottom of the power input and wedge the plastic slot out from the amp.
  • There will be two compartments (one enclosed, one exposed) each containing a fuse. The exposed fuse is the active fuse and the enclosed one is a spare.
Aggiungi Commento
Remove the blown exposed fuse and replace it with the enclosed fuse.  If there is not an extra enclosed fuse, a new fuse must be ordered and inserted into the exposed slot. Remove the blown exposed fuse and replace it with the enclosed fuse.  If there is not an extra enclosed fuse, a new fuse must be ordered and inserted into the exposed slot.
  • Remove the blown exposed fuse and replace it with the enclosed fuse. If there is not an extra enclosed fuse, a new fuse must be ordered and inserted into the exposed slot.
Aggiungi Commento
Conclusione
Cal Poly, Team 24-30, Regan Fall 2012 Membro di Cal Poly, Team 24-30, Regan Fall 2012
CPSU-REGAN-F12S24G30
5 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 29
Ultimi 30 Giorni: 121
Tutti i Tempi: 7,228
