Salta al contenuto principale
Fender 65 Twin Reverb Preamp Tube Replacement
Cosa ti serve
  1. Fender 65 Twin Reverb Preamp Tube Replacement, Preamp Tube: passo 1, immagine 1 di 3 Fender 65 Twin Reverb Preamp Tube Replacement, Preamp Tube: passo 1, immagine 2 di 3 Fender 65 Twin Reverb Preamp Tube Replacement, Preamp Tube: passo 1, immagine 3 di 3
    • Make sure to unplug the power cord!
    • Take off the back panel by unscrewing the four Phillips head screws on the back of the amplifier. You will find the six preamp tubes are the smaller ones on the right. (The picture only shows five of the six.)
    • Keep the screws in a safe place and mark what part they are for.
  2. Fender 65 Twin Reverb Preamp Tube Replacement: passo 2, immagine 1 di 2 Fender 65 Twin Reverb Preamp Tube Replacement: passo 2, immagine 2 di 2
    • Remove the metal casing by gently pressing up against the case and twisting to the right.
  3. Fender 65 Twin Reverb Preamp Tube Replacement: passo 3, immagine 1 di 2 Fender 65 Twin Reverb Preamp Tube Replacement: passo 3, immagine 2 di 2
    • Using the cloth, remove one tube by firmly grasping and gently pulling downwards.
    • Pulling directly downwards prevents damage to the hookup prongs at the bottom of the tube.
  4. Fender 65 Twin Reverb Preamp Tube Replacement: passo 4, immagine 1 di 1
    • Check the tube for any cracks in the glass. Also check to make sure the filaments are not burnt out.
    • If the tube is still functioning or to insert the replacement or, proceed to step five.
  5. Fender 65 Twin Reverb Preamp Tube Replacement: passo 5, immagine 1 di 2 Fender 65 Twin Reverb Preamp Tube Replacement: passo 5, immagine 2 di 2
    • Take the new replacement tube and insert it into the appropriate slot, making sure that the prongs at the end line up with the correct holes.
    • You should hear a click when the tube is secured in place.
    • Repeat these steps with the other three tubes if necessary.
Conclusione
Altre 2 persone hanno completato questa guida.
Andrew Exton
Membro da: 01/26/14
141 Reputazione
1 Guida realizzata
Cal Poly, Team 9-27, Maness Winter 2014 Membro di Cal Poly, Team 9-27, Maness Winter 2014
CPSU-MANESS-W14S9G27
5 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 6,233
