Introduzione
The brakes on anything that moves are practically the most important part. One of the most frightening feelings is pulling a brake lever and not getting a response. With this guide I hope to never make this a reality for anyone.
This guide contains information on how to replace the brake pads on a 2013 Felt Z85 Road Bike. This guide only requires one tool (4mm allen key) and is fairly straightforward.
This guide can also be used as a reference for any modern road bike with Dual-Pivot brakes.
Parti
Pull up on brake-release lever to spread pads for easy access. Release lever on the right side of the wheel. Loosen left nut on wheel until wheel comes free.
  • Pull up on brake-release lever to spread pads for easy access.
  • Release lever on the right side of the wheel.
  • Loosen left nut on wheel until wheel comes free.
Aggiungi Commento
Locate Brake Caliper. Use 4.0 mm allen key to remove main bolt. Rotate counterclockwise to loosen.
  • Locate Brake Caliper.
  • Use 4.0 mm allen key to remove main bolt.
    • Rotate counterclockwise to loosen.
    • Be careful not to lose both the washer and spacer found in-between the bolt and the brake pad mounting hole.
  • Repeat step 2 to remove the pad on the other side.
Aggiungi Commento
Brake Pad: The item being replaced. Spacer: This item will be reused.
  • Brake Pad: The item being replaced.
  • Spacer: This item will be reused.
  • Washer: This item will be reused.
  • 4 mm hex bolt.
  • Note order of mounting hardware for reinstall.
Aggiungi Commento
Conclusione
Ryan Marschall
Membro da: 11/10/2014
123 Reputazione
1 Guida realizzata
USF Tampa, Team 1-21, Donnelly Fall 2014 Membro di USF Tampa, Team 1-21, Donnelly Fall 2014
USFT-DONNELLY-F14S1G21
1 Membro
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 690
