Salta al contenuto principale
Fairphone 1 Midframe Replacement
Cosa ti serve
  1. Fairphone 1 Midframe Replacement, Back Cover: passo 1, immagine 1 di 3 Fairphone 1 Midframe Replacement, Back Cover: passo 1, immagine 2 di 3 Fairphone 1 Midframe Replacement, Back Cover: passo 1, immagine 3 di 3
    • There is a small indentation in the side of the phone near the bottom of the back cover.
    • With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone.
  2. Fairphone 1 Midframe Replacement: passo 2, immagine 1 di 3 Fairphone 1 Midframe Replacement: passo 2, immagine 2 di 3 Fairphone 1 Midframe Replacement: passo 2, immagine 3 di 3
    • Slide the back cover down and remove it from the phone.
  3. Fairphone 1 Midframe Replacement, Battery: passo 3, immagine 1 di 3 Fairphone 1 Midframe Replacement, Battery: passo 3, immagine 2 di 3 Fairphone 1 Midframe Replacement, Battery: passo 3, immagine 3 di 3
    • There is a small indentation in the back of the phone just below the battery.
    • Use a fingernail in this indentation to push the battery toward the top of the phone
    • Pull the battery out away from the phone.
  4. Fairphone 1 Midframe Replacement: passo 4, immagine 1 di 1
    • Remove the battery from your Fairphone.
  5. Fairphone 1 Midframe Replacement, SIM and MicroSD Card: passo 5, immagine 1 di 3 Fairphone 1 Midframe Replacement, SIM and MicroSD Card: passo 5, immagine 2 di 3 Fairphone 1 Midframe Replacement, SIM and MicroSD Card: passo 5, immagine 3 di 3
    • Use your finger to slide the SIM card straight down out of its tray.
    • Remove the SIM card from your Fairphone.
    • Repeat this procedure if you have a second SIM card.
    • Be sure to remove all SIM cards before servicing your phone.
  6. Fairphone 1 Midframe Replacement: passo 6, immagine 1 di 2 Fairphone 1 Midframe Replacement: passo 6, immagine 2 di 2
    • If you have a microSD card, use your finger to slide it straight out of its slot.
    • Remove the microSD card from your phone.
  7. Fairphone 1 Midframe Replacement, Midframe Assembly: passo 7, immagine 1 di 1
    • Remove the five 3.9 mm Phillips #000 screws securing the midframe to the display assembly.
  8. Fairphone 1 Midframe Replacement: passo 8, immagine 1 di 3 Fairphone 1 Midframe Replacement: passo 8, immagine 2 di 3 Fairphone 1 Midframe Replacement: passo 8, immagine 3 di 3
    • The midframe is secured to the display assembly by several small plastic clips.
    • Use an opening pick to carefully pry the midframe away from the display assembly.
    • Start just below the volume rocker and work your way down toward the bottom of the phone, freeing the plastic clips along the side.
  9. Fairphone 1 Midframe Replacement: passo 9, immagine 1 di 2 Fairphone 1 Midframe Replacement: passo 9, immagine 2 di 2
    • Carefully round the corner, separating the midframe from the display assembly.
  10. Fairphone 1 Midframe Replacement: passo 10, immagine 1 di 1
    • After rounding the next corner, the midframe should be free along the bottom and the sides.
  11. Fairphone 1 Midframe Replacement: passo 11, immagine 1 di 3 Fairphone 1 Midframe Replacement: passo 11, immagine 2 di 3 Fairphone 1 Midframe Replacement: passo 11, immagine 3 di 3
    • Run the opening pick and pry along the top seam.
    • To avoid bending or damaging the opening picks, do not pry near to the power switch, USB port, or headphone jack.
  12. Fairphone 1 Midframe Replacement: passo 12, immagine 1 di 1
    • Separate any remaining clips and remove the midframe from the phone.
  13. Fairphone 1 Midframe Replacement, Midframe: passo 13, immagine 1 di 2 Fairphone 1 Midframe Replacement, Midframe: passo 13, immagine 2 di 2
    • The speakerphone speaker is held to the midframe with some mild adhesive.
    • Use the tip of a spudger to pry the speaker off of the midframe.
  14. Fairphone 1 Midframe Replacement: passo 14, immagine 1 di 1
    • Remove the speaker from the midframe.
Conclusione
Altre 10 persone hanno completato questa guida.
Sam Goldheart
Membro da: 10/18/12
465.771 Reputazione
538 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.817 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 10,939
