Introduzione
Replacing the battery in your Fairphone is easy and requires no tools.
Strumenti
Nessun attrezzo richiesto.
There is a small indentation in the side of the phone near the bottom of the back cover. With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone. With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone.
  • There is a small indentation in the side of the phone near the bottom of the back cover.
  • With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone.
Aggiungi Commento
Slide the back cover down and remove it from the phone. Slide the back cover down and remove it from the phone. Slide the back cover down and remove it from the phone.
  • Slide the back cover down and remove it from the phone.
Aggiungi Commento
There is a small indentation in the back of the phone just below the battery. Use a fingernail in this indentation to push the battery toward the top of the phone Pull the battery out away from the phone.
  • There is a small indentation in the back of the phone just below the battery.
  • Use a fingernail in this indentation to push the battery toward the top of the phone
  • Pull the battery out away from the phone.
Aggiungi Commento
Remove the battery from your Fairphone.
  • Remove the battery from your Fairphone.
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Andrew Optimus Goldberg
Membro da: 17/10/2009
368.439 Reputazione
1.263 Guide realizzate
iFixit Membro di iFixit
Community
116 Membri
5.773 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 57
Tutti i Tempi: 7,543
