Introduzione
If the accessory holder is no longer able to hold the multiple tools associated with the vacuum, this guide outlines the its replacement.
Parti
Nessuna parte richiesta.
On the back of the vacuum, pull the handle connected to the hose away from the vacuum. On the back of the vacuum, pull the handle connected to the hose away from the vacuum.
  • On the back of the vacuum, pull the handle connected to the hose away from the vacuum.
Aggiungi Commento
Grasp the thick smooth collar at the bottom of the hose and twist left (counterclockwise) to remove the hose. Grasp the thick smooth collar at the bottom of the hose and twist left (counterclockwise) to remove the hose.
  • Grasp the thick smooth collar at the bottom of the hose and twist left (counterclockwise) to remove the hose.
Aggiungi Commento
Using a T15 Torx Security Screwdriver, remove the screw on each side of the indention in which the hose normally rests.
  • Using a T15 Torx Security Screwdriver, remove the screw on each side of the indention in which the hose normally rests.
Aggiungi Commento
Upon removal of the two screws, the accessory holder can be removed from the vacuum body.
  • Upon removal of the two screws, the accessory holder can be removed from the vacuum body.
Aggiungi Commento
Conclusione
Celina Burchett
Membro da: 13/10/2014
1.031 Reputazione
8 Guide realizzate
Clemson, Team 2-2, Benson Fall 2014 Membro di Clemson, Team 2-2, Benson Fall 2014
CLEM-BENSON-F14S2G2
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 281
