Salta al contenuto principale
Eureka 1660SP Roller Replacement
Cosa ti serve
  1. Eureka 1660SP Roller Replacement, Roller: passo 1, immagine 1 di 2 Eureka 1660SP Roller Replacement, Roller: passo 1, immagine 2 di 2
    • Press the black separator switch and lightly pull the bottom half away from the top.
  2. Eureka 1660SP Roller Replacement: passo 2, immagine 1 di 2 Eureka 1660SP Roller Replacement: passo 2, immagine 2 di 2
    • Remove the vacuum head from the lower half of the body.
  3. Eureka 1660SP Roller Replacement: passo 3, immagine 1 di 3 Eureka 1660SP Roller Replacement: passo 3, immagine 2 di 3 Eureka 1660SP Roller Replacement: passo 3, immagine 3 di 3
    • Turn the vacuum head wheels up and remove all seven 13.9mm screws from the bottom using a #2 Phillips head screwdriver.
    • Separate the top and bottom of the vacuum head. Set the top aside.
  4. Eureka 1660SP Roller Replacement: passo 4, immagine 1 di 2 Eureka 1660SP Roller Replacement: passo 4, immagine 2 di 2
    • Turn the vacuum head's bottom over so that the inside of the head is facing up.
    • Using a Phillips #00 screwdriver, press down on metal bar of the roller on one side until it releases from the housing.
    • Turn the vacuum head's bottom over and pull at the roller and bar until they are completely out of the housing.
  5. Eureka 1660SP Roller Replacement: passo 5, immagine 1 di 1
    • Press the new bar and roller into place.
    • Replace the screws.
Linea Traguardo
UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 Membro di UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G1
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 448
