Introduzione
Replace the encoder strip.
Parti
Nessuna parte richiesta.
Remove the back panel by inserting your fingers into the indentations next to the tabs. Press the tabs inward towards each other while pulling the back panel toward you.
  • Remove the back panel by inserting your fingers into the indentations next to the tabs. Press the tabs inward towards each other while pulling the back panel toward you.
Aggiungi Commento
Using the T10 Torx Security Bit Screwdriver, unscrew the screws on the upper left and right corners of the inner panel to remove the inner back panel. Using the T10 Torx Security Bit Screwdriver, unscrew the screws on the upper left and right corners of the inner panel to remove the inner back panel.
  • Using the T10 Torx Security Bit Screwdriver, unscrew the screws on the upper left and right corners of the inner panel to remove the inner back panel.
Aggiungi Commento
Press down on the two plastic hinges to remove the upper portion of printer. Press down on the two plastic hinges to remove the upper portion of printer.
  • Press down on the two plastic hinges to remove the upper portion of printer.
Aggiungi Commento
To unplug the speaker wire, grasp the plastic plug on the end of the speaker wire then gently pull the plug away from the printer until removed.
  • To unplug the speaker wire, grasp the plastic plug on the end of the speaker wire then gently pull the plug away from the printer until removed.
Aggiungi Commento
Rotate the printer so the paper tray is facing towards you. Gently lift the scanner tray up and away from the printer.
  • Rotate the printer so the paper tray is facing towards you.
  • Gently lift the scanner tray up and away from the printer.
  • Press the gray plastic tabs inward toward to release the tabs from the printer.
Aggiungi Commento
Returning to the back of the printer, remove the scanner from the back hinges.
  • Returning to the back of the printer, remove the scanner from the back hinges.
    • With pressure applied, the scanner will detach easily.
It would be easer to do steps 7 & 8 before step 6.
Richard Scott - Replica
Gently grasp and unplug the two white ribbon cables from the printer body.
  • Gently grasp and unplug the two white ribbon cables from the printer body.
    • Be sure to grasp the cable at the connector and not to pull on the wires themselves.
Aggiungi Commento
Unplug the white plastic multi-wire connector with the orange, black, red, and brown wires from it's port.
  • Unplug the white plastic multi-wire connector with the orange, black, red, and brown wires from it's port.
    • Be sure to grasp the white connector and not to pull on the wires themselves.
Aggiungi Commento
Detach the scanner tray from the printer by lifting the scanner tray off the printer body.
  • Detach the scanner tray from the printer by lifting the scanner tray off the printer body.
Aggiungi Commento
Locate the panel labeled with a HP support link sticker. Release the tab by the support link sticker.
  • Locate the panel labeled with a HP support link sticker.
  • Release the tab by the support link sticker.
  • Remove the black screw below the tab.
Aggiungi Commento
Remove the two black screws closest to the printer tray.
  • Remove the two black screws closest to the printer tray.
Aggiungi Commento
Unhook the encoder strip from its small silver hooks and remove it from the printer.
  • Unhook the encoder strip from its small silver hooks and remove it from the printer.
  • To replace, feed the new encoder strip through the silver hooks.
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Jeremy Mahrt
Membro da: 08/05/2011
280 Reputazione
2 Guide realizzate
Cal Poly, Team 12-31, Maness Spring 2011 Membro di Cal Poly, Team 12-31, Maness Spring 2011
CPSU-MANESS-S11S12G31
5 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 58
Ultimi 30 Giorni: 242
Tutti i Tempi: 18,400
