Parti
Nessuna parte richiesta.
Use a spudger to pry open the case of your device to reveal the inside. Use a spudger to pry open the case of your device to reveal the inside.
  • Use a spudger to pry open the case of your device to reveal the inside.
Aggiungi Commento
Disconnect the LCD cable from the motherboard by pressing together the two sides of the clamp to separate the device into two. Disconnect the LCD cable from the motherboard by pressing together the two sides of the clamp to separate the device into two.
  • Disconnect the LCD cable from the motherboard by pressing together the two sides of the clamp to separate the device into two.
Aggiungi Commento
Use the spudger to pry the LCD from the clamps holding it to the case.
  • Use the spudger to pry the LCD from the clamps holding it to the case.
Aggiungi Commento
If you need to remove the back part of the casing, after disconnecting the LCD display from the motherboard, remove the screws holding down the motherboard. Remove the plastic power and volume buttons. remove the two side grips of the device. If you need to remove the back part of the casing, after disconnecting the LCD display from the motherboard, remove the screws holding down the motherboard. Remove the plastic power and volume buttons. remove the two side grips of the device.
  • If you need to remove the back part of the casing, after disconnecting the LCD display from the motherboard, remove the screws holding down the motherboard. Remove the plastic power and volume buttons. remove the two side grips of the device.
Aggiungi Commento
Remove the motherboard, speaker, and battery as a whole, which leaves just the back casing of the device. Remove the motherboard, speaker, and battery as a whole, which leaves just the back casing of the device.
  • Remove the motherboard, speaker, and battery as a whole, which leaves just the back casing of the device.
Aggiungi Commento
Conclusione
Timothy
Membro da: 21/01/2015
505 Reputazione
5 Guide realizzate
USF Tampa, Team 9-2, Brown Winter 2015 Membro di USF Tampa, Team 9-2, Brown Winter 2015
USFT-BROWN-W15S9G2
5 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 89
