Salta al contenuto principale
Dyson Ball Multi Floor Upright Main Filter Replacement
Cosa ti serve
  1. Dyson Ball Multi Floor Upright Main Filter  Replacement, Main Filter: passo 1, immagine 1 di 3 Dyson Ball Multi Floor Upright Main Filter  Replacement, Main Filter: passo 1, immagine 2 di 3 Dyson Ball Multi Floor Upright Main Filter  Replacement, Main Filter: passo 1, immagine 3 di 3
    • For the main filter, locate the body of the vacuum by looking for the cylinder with the orange top. Use your thumb to press down on the red button towards the back of the orange piece.
    • After pressing down on the red button, the body of the vacuum will easily be removed from the vacuum stand.
  2. Dyson Ball Multi Floor Upright Main Filter  Replacement: passo 2, immagine 1 di 3 Dyson Ball Multi Floor Upright Main Filter  Replacement: passo 2, immagine 2 di 3 Dyson Ball Multi Floor Upright Main Filter  Replacement: passo 2, immagine 3 di 3
    • Once the main body of the vacuum is removed, locate the clear handle on the top of the body. There is a purple label that says "Filter".
    • Lift up the clear handle to reveal the main cylindrical filter. Pull out the purple filter piece to replace.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 21-2, Maness Winter 2017 Membro di Cal Poly, Team 21-2, Maness Winter 2017
CPSU-MANESS-W17S21G2
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 48
Tutti i Tempi: 3,606
