Introduzione
Can't watch your favorite movie? Replacing the optical disc drive may help.
Before removing the screen, be sure to turn off and unplug your device.
  • Before removing the screen, be sure to turn off and unplug your device.
  • Flip your device over, so the bottom is facing up.
Aggiungi Commento
Remove the back cover held by thirteen 3.175 mm head, 9.525 mm length pan-head Phillips screws.
  • Remove the back cover held by thirteen 3.175 mm head, 9.525 mm length pan-head Phillips screws.
  • One of the screws is covered by a seal. Breaking this seal will void your warranty.
Aggiungi Commento
Use a plastic opening tool to pop open the back case. Do not separate the back cover completely, wires are still connected to both sides. Do not separate the back cover completely, wires are still connected to both sides.
  • Use a plastic opening tool to pop open the back case.
  • Do not separate the back cover completely, wires are still connected to both sides.
Aggiungi Commento
Hold the back cover upright and remove the black tape connecting the wire group to the cover. Remove the bottom two pieces of tape connecting wires to the CD tray.
  • Hold the back cover upright and remove the black tape connecting the wire group to the cover.
  • Remove the bottom two pieces of tape connecting wires to the CD tray.
Aggiungi Commento
Locate the small circuit board on the underside of the buttons. Remove the circuit board for the buttons, held by six 3.175 mm head, 4.762 mm length flat-head Phillips screws.
  • Locate the small circuit board on the underside of the buttons.
  • Remove the circuit board for the buttons, held by six 3.175 mm head, 4.762 mm length flat-head Phillips screws.
Aggiungi Commento
Remove the three wire connections that are located on the main (largest) circuit board. The connection can be gently removed with a plastic opening tool or with your fingers by pinching the ends and pulling. The connection can be gently removed with a plastic opening tool or with your fingers by pinching the ends and pulling.
  • Remove the three wire connections that are located on the main (largest) circuit board.
  • The connection can be gently removed with a plastic opening tool or with your fingers by pinching the ends and pulling.
Aggiungi Commento
Remove the optical disc drive by lifting it off the three pegs on the bottom case. Remove the optical disc drive by lifting it off the three pegs on the bottom case.
  • Remove the optical disc drive by lifting it off the three pegs on the bottom case.
Aggiungi Commento
Now that the optical drive is removed from the case, flip it over and locate the ribbon cable. Gently pull out the two sides of the brown tab underneath the ribbon cable, see images for detail. Once both sides of the tab are out, it should require no force to pull the ribbon cable out of the connection on the optical drive.
  • Now that the optical drive is removed from the case, flip it over and locate the ribbon cable.
  • Gently pull out the two sides of the brown tab underneath the ribbon cable, see images for detail.
  • Once both sides of the tab are out, it should require no force to pull the ribbon cable out of the connection on the optical drive.
Aggiungi Commento
Now the optical drive should be removed and still connected to the circuit board which was underneath the buttons.
  • Now the optical drive should be removed and still connected to the circuit board which was underneath the buttons.
  • Desolder the optical drive wires from the circuit board.
  • If the wires need to be removed from the circuit board, you may need to use an adhesive solvent to fully dissolve the glue.
  • For proper soldering and desoldering techniques reference How To Solder and Desolder Connections.
  • Soldering requires the iron to be at hot temperatures and can cause burns. Wear safety glasses as needed. Be extremely careful with the wires and board in this step as they could melt, burn, or break.
Aggiungi Commento
Conclusione
Cal Poly, Team 8-10, Regan Spring 2014 Membro di Cal Poly, Team 8-10, Regan Spring 2014
CPSU-REGAN-S14S8G10
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 166
