Remove the six 13 mm casing screws with the #0 Phillips screwdriver.
  • Remove the six 13 mm casing screws with the #0 Phillips screwdriver.
Aggiungi Commento
Separate the screwdriver casing halves with the plastic opening tool. Separate the screwdriver casing halves with the plastic opening tool.
  • Separate the screwdriver casing halves with the plastic opening tool.
Aggiungi Commento
Slide the bit chuck assembly out from the casing half.
  • Slide the bit chuck assembly out from the casing half.
Aggiungi Commento
Apply a dab of grease to the end of the drill motor coupler.
  • Apply a dab of grease to the end of the drill motor coupler.
Aggiungi Commento
Insert new bit chuck assembly into the drill casing.
  • Insert new bit chuck assembly into the drill casing.
Aggiungi Commento
Conclusione
Tyler Vincent
Membro da: 24/02/2014
401 Reputazione
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 287
