Introduzione
Use this guide to replace a defective battery LED indicator. A new battery LED is need to complete this repair.
Remove the six 13 mm case screws with a #0 Phillips screwdriver.
  • Remove the six 13 mm case screws with a #0 Phillips screwdriver.
Aggiungi Commento
Using a plastic opening tool, separate the casing halves to expose the contents of the cordless screwdriver. Using a plastic opening tool, separate the casing halves to expose the contents of the cordless screwdriver.
  • Using a plastic opening tool, separate the casing halves to expose the contents of the cordless screwdriver.
Aggiungi Commento
Remove printed circuit board, LED, battery, and motor assembly from the screwdriver casing. Use a soldering iron to melt the solder from the LED's two pins on the printed circuit board. Remove the LED from the circuit board while the solder is still melted.
  • Remove printed circuit board, LED, battery, and motor assembly from the screwdriver casing.
  • Use a soldering iron to melt the solder from the LED's two pins on the printed circuit board.
  • Remove the LED from the circuit board while the solder is still melted.
Aggiungi Commento
Place the positive leg of the new LED through the positive hole in the printed circuit board and solder it into place. Place the negative leg of the LED through the negative hold in the printed circuit board and solder it into place.
  • Place the positive leg of the new LED through the positive hole in the printed circuit board and solder it into place.
  • Place the negative leg of the LED through the negative hold in the printed circuit board and solder it into place.
Aggiungi Commento
Conclusione
Tyler Vincent
Membro da: 24/02/2014
401 Reputazione
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 558
