Introduzione
Use this guide to replace the 3.7 lithium-ion battery inside the DualShock 4.
Using the Phillips #00 Screwdriver, remove the four 6.0 mm screws securing the rear cover to the controller.
  • Using the Phillips #00 Screwdriver, remove the four 6.0 mm screws securing the rear cover to the controller.
  • Do not forcefully loosen the screws, as it will amount to permanent damage of the threads, making removal impossible.
Aggiungi Commento
Beginning with the left shoulder: Pinch the left shoulder of the controller to introduce an opening. Wedge a plastic opening tool into the opening and slide it up towards the joystick.
  • Beginning with the left shoulder:
    • Pinch the left shoulder of the controller to introduce an opening.
    • Wedge a plastic opening tool into the opening and slide it up towards the joystick.
    • Pull down on the plier to crack open the casing.
  • Repeat these steps for the right shoulder.
Shoulders are where L1/L2/R1/R2 are, not the %#*@ handles. Confusing instructions.
foxhoundunit89 - Replica
Quick tip: Be VERY careful at this step not to dislodge the tiny spring attached to the L2/R2 buttons. While removing the cover, it's easy to pull off either L2/R2 button. Inadvertently pulling off either button will also remove the tiny spring as well. While not too difficult to reassemble, it's not obvious where the spring goes as the spring is almost completely hidden along the side of the button (on the inside).
I just successfully completed analog stick replacements for two controllers. I completed the first repair without any trouble but managed to dislodge (and almost lose) the spring on the second time around. Needless to say, I spent some time trying to figure out where the spring is supposed to go (no photos of this anywhere). By sheer luck, I figured it out on my own. :)
Good luck and take your time--especially the first time!
Michael Whang - Replica
couldn't have posted pics for me? :D
kimsballs -
Golden tip but I would add a thing or two.
Most probably both triggers R1&R2 will stay in lower half of the pad case with springs hanging there.
You must take them of their lower case sockets before assembly and fit them bellow L1&L2
When you feel click when fitting them and spring works like on normal assembled pad you're done.
If thats not the case do not try to assemble lower casing half as triggers will not work properly.
Simon -
if you lost the springs unfortunately, the triggers would still work but it is harder to get to the precise digital press. In other words you will have hard time to create a light press than a hard press.
meaningless -
Wedge a plastic opening tool into the case-splittings and pull down to crack open the casing near the following buttons: Share button Options button
  • Wedge a plastic opening tool into the case-splittings and pull down to crack open the casing near the following buttons:
    • Share button
    • Options button
  • Split the plastic covers of the controller apart, taking note that they will still be attached by circuit board ribbons.
  • Three small pieces are often released from the framework. To prevent loss, maintain a controlled work field.
    • 2 Trigger Springs
    • 1 Grey Reset Button Extension
You can't just pull the casing halves apart. There is a plastic bar that is part of the casing and separates the L1 and R1 buttons from the L2 and R2 buttons. To get this loose, pull the casing outward perpendicular to the L and R buttons until you can slide the L2 and R2 buttons from behind the plastic bar.
dzturbd - Replica
SO yesterday replaced the thumb stick on my controller, and now the R2 button is stuck, know any way to remedy this?
ScootsMcgoots -
I know you put a warning, but I lost the grey reset button extension. Any idea where to get a replacement part?
miamiman77 - Replica
Hey, not even sure when you wrote this, but wanted to share my solution for this problem. I lost one of my reset button rubber pieces when I was doing a different repair, and found that a standard bamboo skewer is just about the perfect diameter to function as a replacement. Just cut it to the proper length and you should be able to get it in there and get your reset functionality back.
tcbrekke -
You don't really need it. A long paper clip will work fine.
Ron Smith - Replica
I've removed and changed all buttons all seemed ok but now the options and share button don't work, as in when I pressed them down there is no longer a click (bounce) I'm certain it's back in the correct place and I don't think they can be put the wrong way up, does anyone have any advice please :)
Rachel - Replica
My share button stopped 'clicking'. When I stripped the controller down I noticed a small copper coloured dimple on the motherboard was depressed instead of proud like the one for the options button. With bluetack I was able to pull it out but each time I tested it with my finger it clicked once and stayed depressed. I don't think there is a permanent solution to this as it's probably metal fatigue or similar so i put a tiny bit of blue tack overy the dimple so the plunger could push that bit further and hopefully pull it out each time. Seems to work as I reassemble the controller. Fingers crossed it holds out a while! I'd love to know if someone else had a different solution.
The5HD -
I had an extra part, and it wasn’t gray. Thank goodness for the picture of the black one. It’s rubbery. The small end should be inserted down towards the gold colored spot. It’s next to the word RESET on the mobo.
J Coyote - Replica
When reassembling: If, like me, your R2/L2 buttons stayed with the bottom of the controller when you took it apart, it will be impossible to reassemble and get the tiny springs back in place.
To remedy, remove the buttons, and attach them, with the springs correctly placed, to the top of the controller. There are two tiny grooves, one on the button, and one on the controller top, into which the spring fits.
Jeff Human - Replica
Jeff, we owe you a six pack for this comment.
James Goldie -
Detach the motherboard ribbon connecting the two sides of the controller by pulling it straight out with your fingers. Note the orientation of the cable and make sure it faces the right way when you reconnect it. After the two halves are separated, place the top of the controller off to the side.
  • Detach the motherboard ribbon connecting the two sides of the controller by pulling it straight out with your fingers.
    • Note the orientation of the cable and make sure it faces the right way when you reconnect it.
  • After the two halves are separated, place the top of the controller off to the side.
can you share the battery dimension?
luxusmirajane - Replica
Using the blunt forceps, remove the battery plug by gently rocking the forceps side-by-side to loosen the plug. After removal of the plug from the motherboard, the battery can be lifted off of the controller. Hasty removal of the battery plug could warp the plastic grips of the plug.
  • Using the blunt forceps, remove the battery plug by gently rocking the forceps side-by-side to loosen the plug.
  • After removal of the plug from the motherboard, the battery can be lifted off of the controller.
  • Hasty removal of the battery plug could warp the plastic grips of the plug.
For the replacement battery I found that the Turnigy 2000mAh 1S 1C Lipo w/ 2 Pin JST-PH worked perfectly while also being a budget option at only $2.54 USD before shipping. However ONLY INSTALL AFTER CHANGING THE POLARITY OF THE CONNECTOR, this can be done with a pin or craft knife with relative ease. After doing this the controller has doubled in battery life. It required no modification to the controllers internals only extra care to ensure the longer cables didn’t get pinched in reassembly.
Ryan - Replica
Conclusione
Altre 82 persone hanno completato questa guida.
Mark
Membro da: 21/01/2014
4.731 Reputazione
13 Guide realizzate
Cal Poly, Team 6-21, Maness Winter 2014 Membro di Cal Poly, Team 6-21, Maness Winter 2014
CPSU-MANESS-W14S6G21
4 Membri
24 Guide realizzate
My Dualshock 4 wont turn on after the battery replacement.
Any idea on why this happened?
Alexander - Replica
have you tried to charge it?
Mohamed Aden -
I had a problem with my console but with your guide it is possible to solve this one I think.
Praska - Replica
The only replacement battery option listed in the 'relevant parts' section of the guide is for a used battery. Here is a a link to a new replacement battery for those that don't want to do this again in a few months. It is higher capacity than the OEM battery (1300mAh instead of 1000mAh) so it will last longer. Hope this helps!
New Replacement Battery for Dualshock 4 Controller
Mike - Replica
My samsung galaxy tab 2 7inch screen goes black help
clarissa owens - Replica
I found a replacement battery here, you have to mod the tray a little, but it works like a champ and doubles the life.
http://www.ebay.com/itm/PS4-Controller-B...
binazriel - Replica
The x button on my controller want working properly so I ordered new rubber mounts. I followed the guide, taking my time to make sure I didn't damage anything.
With the new rubber in place I put everything back together and the controller was working fine but now I've realised it doesn't charge. The battery goes completely dead and switches off. If I then connect it with usb cable it doesn't charge but will turn on the controller for maybe 10 seconds before switching off again.
Anyone any idea what is going on? Thanks.
Kenny - Replica
my controller is not starting today
Harry Patidar - Replica
Did this fix to the letter, controller works now but the light bar does not and I'm unsure if it charges. It shows it's fully charged. Could it be that the micro-usb connection is frapped?
the00brotherhood - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 77
Ultimi 7 Giorni: 560
Ultimi 30 Giorni: 2,998
Tutti i Tempi: 133,274
