Salta al contenuto principale
Disconnecting Garmin Nuvi 680 Screen Wiring
Cosa ti serve
  1. Disconnecting Garmin Nuvi 680 Screen Wiring, Outer Case: passo 1, immagine 1 di 1
    • Flip open the antenna on the back of the device.
    • Remove the two 4.42 mm screws on the antenna cover using a T5 Torx screwdriver.
  2. Disconnecting Garmin Nuvi 680 Screen Wiring: passo 2, immagine 1 di 1
    • Remove the antenna cover.
  3. Disconnecting Garmin Nuvi 680 Screen Wiring: passo 3, immagine 1 di 1
    • The yellow wire is connected to the motherboard, so you cannot disconnect it until you finish opening the device.
    • Pull the antenna circuit board out of its case.
  4. Disconnecting Garmin Nuvi 680 Screen Wiring: passo 4, immagine 1 di 2 Disconnecting Garmin Nuvi 680 Screen Wiring: passo 4, immagine 2 di 2
    • Insert the pointed end of a spudger into the leftmost slit of the antenna case.
    • Push the spudger to the right.
    • Slide the antenna case out slowly or you may lose the antenna's spring. The spring is inside the black plastic that holds the antenna case to the device.
    • Slide the antenna case out of the device.
    • Reinstallation tip: first reassemble the antenna casing (place antenna back into its plastic cover), and then re-insert the entire assembly back into the GPS body.
  5. Disconnecting Garmin Nuvi 680 Screen Wiring: passo 5, immagine 1 di 1
    • Remove the two screws on the back of the outer case using a T5 Torx screwdriver.
    • These screws are 10.82 mm long.
  6. Disconnecting Garmin Nuvi 680 Screen Wiring: passo 6, immagine 1 di 2 Disconnecting Garmin Nuvi 680 Screen Wiring: passo 6, immagine 2 di 2
    • Gently pull apart the front and back of the device. The front and back are still connected by ribbon cables.
    • Starting along the top, separate the front and back of the device by pushing an iPod-opening tool into the crack along each side of the case.
  7. Disconnecting Garmin Nuvi 680 Screen Wiring, Antenna: passo 7, immagine 1 di 2 Disconnecting Garmin Nuvi 680 Screen Wiring, Antenna: passo 7, immagine 2 di 2
    • Use a spudger to disconnect the yellow antenna wire from the ZIF connector by opening the brown latch holding the wire in place.
    • Remove the antenna.
  8. Disconnecting Garmin Nuvi 680 Screen Wiring, Screen Wiring: passo 8, immagine 1 di 1
    • Do not remove the ribbon cables without lifting the latch or the cable will be damaged.
    • Lift the latches on the ribbon cable connectors. All the ribbon cables may have latches. The right most latch may have a latch that flips in the opposite direction from the others.
    • Gently pull the ribbon cables out of their connectors. They should slide out easily.
    • Do not separate the two halves of the device yet or the on/off cable may be severed.
  9. Disconnecting Garmin Nuvi 680 Screen Wiring: passo 9, immagine 1 di 2 Disconnecting Garmin Nuvi 680 Screen Wiring: passo 9, immagine 2 di 2
    • Gently pull the cable for the on/off button straight up to remove it.
    • The two halves of the device may now be separated.
Conclusione
Allen Pasch
Membro da: 01/20/11
261 Reputazione
1 Guida realizzata
Cal Poly, Team 5-22, Amido Winter 2011 Membro di Cal Poly, Team 5-22, Amido Winter 2011
CPSU-AMIDO-W11S5G22
5 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,466
