Salta al contenuto principale
Disassembling the Garmin eTrex Vista-H Outer Case
Cosa ti serve
  1. Disassembling the Garmin eTrex Vista-H Outer Case, Removing Battery: passo 1, immagine 1 di 1
    • Flip the device to the backside, and locate the metal tab at the center of the back cover.
  2. Disassembling the Garmin eTrex Vista-H Outer Case: passo 2, immagine 1 di 1
    • Lift the metal tab up, and rotate it counterclockwise. This will unlock the back case cover.
  3. Disassembling the Garmin eTrex Vista-H Outer Case: passo 3, immagine 1 di 2 Disassembling the Garmin eTrex Vista-H Outer Case: passo 3, immagine 2 di 2
    • Lift the battery plate off to either insert or remove 2 AA batteries.
  4. Disassembling the Garmin eTrex Vista-H Outer Case, Disassembling the Garmin eTrex Vista-H Outer Case: passo 4, immagine 1 di 2 Disassembling the Garmin eTrex Vista-H Outer Case, Disassembling the Garmin eTrex Vista-H Outer Case: passo 4, immagine 2 di 2
    • With the wedge side of a spudger (or a small, flat head screwdriver), remove the black rubber case support from the device body.
  5. Disassembling the Garmin eTrex Vista-H Outer Case: passo 5, immagine 1 di 3 Disassembling the Garmin eTrex Vista-H Outer Case: passo 5, immagine 2 di 3 Disassembling the Garmin eTrex Vista-H Outer Case: passo 5, immagine 3 di 3
    • With the pick side of a spudger (or tweezers), peel the sticky tape from the device.
  6. Disassembling the Garmin eTrex Vista-H Outer Case: passo 6, immagine 1 di 1
    • Split the front and rear panels by inserting a small pointed tool (such as a pen point or a screwdriver tip SL1.5) in the 5 plastic tabs along the sides of the device.
    • Do not remove the back panels quickly. If too much force is applied, there is a wire connection that will break.
    • CAUTION! Be careful not to force the tabs inward. This will result in broken tabs.
  7. Disassembling the Garmin eTrex Vista-H Outer Case: passo 7, immagine 1 di 2 Disassembling the Garmin eTrex Vista-H Outer Case: passo 7, immagine 2 di 2
    • With tweezers (or your fingernails), carefully disconnect the wires between the PC input and the motherboard.
Conclusione
Altre 7 persone hanno completato questa guida.
Ryan Green
Membro da: 10/17/10
93 Reputazione
1 Guida realizzata
Cal Poly, Team 21-30, Regan Fall 2010 Membro di Cal Poly, Team 21-30, Regan Fall 2010
CPSU-REGAN-F10S21G30
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 4,982
