Carefully prise the back cover off the phone.
  • Carefully prise the back cover off the phone.
Aggiungi Commento
Remove Battery, SIM Card, and MicroSD
  • Remove Battery, SIM Card, and MicroSD
  • Remove the four screws located around the edge of the case. They should be very small phillips heads.
Aggiungi Commento
Using a flathead screwdriver, carefully prise the black plastic away. It's held in with a series of clips, and should come away easily.
  • Using a flathead screwdriver, carefully prise the black plastic away. It's held in with a series of clips, and should come away easily.
Aggiungi Commento
Carefully remove the ribbon cable that connects the capacitive screen to the main board. You need to carefully lift the small tab, then pull the cable out.
  • Carefully remove the ribbon cable that connects the capacitive screen to the main board. You need to carefully lift the small tab, then pull the cable out.
Aggiungi Commento
Now using the flathead screwdriver, prise the plastic that makes up the front, away from the circuit board. Like the back piece, it has a series of clips around the edge, and should lift free without much effort. Now using the flathead screwdriver, prise the plastic that makes up the front, away from the circuit board. Like the back piece, it has a series of clips around the edge, and should lift free without much effort.
  • Now using the flathead screwdriver, prise the plastic that makes up the front, away from the circuit board. Like the back piece, it has a series of clips around the edge, and should lift free without much effort.
Aggiungi Commento
There you have it. Amazingly simple to take apart this phone. There you have it. Amazingly simple to take apart this phone.
  • There you have it. Amazingly simple to take apart this phone.
Aggiungi Commento
Conclusione
Jacob
Membro da: 27/04/2013
121 Reputazione
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,557
