Introduzione
This guide is a prerequisite for replacing other parts of an Xbox 360 E.
Parti
Nessuna parte richiesta.
Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
  • Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
  • Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
Aggiungi Commento
Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
  • Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
  • Periodically pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
Aggiungi Commento
Continue sliding the spudger along the perimeter of the left grated face of the Xbox. Pull the top panel off. Pull the top panel off.
  • Continue sliding the spudger along the perimeter of the left grated face of the Xbox.
  • Pull the top panel off.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Jennifer
Membro da: 02/02/2014
1.449 Reputazione
4 Guide realizzate
Cal Poly, Team 2-11, Amido Winter 2014 Membro di Cal Poly, Team 2-11, Amido Winter 2014
CPSU-AMIDO-W14S2G11
4 Membri
11 Guide realizzate
I broke my spudger! May I use anything besides that?
Colin2 Schrek - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,088
