Parti
Nessuna parte richiesta.
Use a large plastic opening tool along the rear panel: There are 4 clips to release. There are 4 clips to release.
  • Use a large plastic opening tool along the rear panel:
    • There are 4 clips to release.
Aggiungi Commento
Slide the cover along the plastic frame. Slide the cover along the plastic frame.
  • Slide the cover along the plastic frame.
Aggiungi Commento
Slide off the largest plastic pieces.
  • Slide off the largest plastic pieces.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Bend the second small plastic piece to release it from the rubber piece. Now you can slide it out. Now you can slide it out.
  • Bend the second small plastic piece to release it from the rubber piece.
  • Now you can slide it out.
Aggiungi Commento
Slide out the hard drive as shown in the picture Make sure to slide as shown or you may damage the USB bridge logic board.
  • Slide out the hard drive as shown in the picture
  • Make sure to slide as shown or you may damage the USB bridge logic board.
Aggiungi Commento
Remove the 4 rubber piece from the plastic frame at each corner. Remove the 4 rubber piece from the plastic frame at each corner.
  • Remove the 4 rubber piece from the plastic frame at each corner.
Aggiungi Commento
Remove the rubber piece from the  SATA/USB bridge logic board.
  • Remove the rubber piece from the SATA/USB bridge logic board.
Aggiungi Commento
Remove both screws holding the retaining plate and the hard drive. Slide the retaining plate in order to disconnect the SATA connector.
  • Remove both screws holding the retaining plate and the hard drive.
  • Slide the retaining plate in order to disconnect the SATA connector.
Aggiungi Commento
Remove both screws holding the retaining plate with the logic board.
  • Remove both screws holding the retaining plate with the logic board.
Aggiungi Commento
Conclusione
Gaetan
Membro da: 26/12/2012
9.249 Reputazione
30 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,309
