Salta al contenuto principale
Disassembling Toshiba NB205 N330PK Back Panels
Cosa ti serve
  1. Disassembling Toshiba NB205 N330PK Back Panels, Disassembling Toshiba NB205 N330PK Back Panels: passo 1, immagine 1 di 2 Disassembling Toshiba NB205 N330PK Back Panels, Disassembling Toshiba NB205 N330PK Back Panels: passo 1, immagine 2 di 2
    • Using the Phillips #0 in the bit driver, carefully loosen and remove the single 5mm screw.
    • With the retaining screw removed, lift the panel upwards to separate it from the netbook.
  2. Disassembling Toshiba NB205 N330PK Back Panels: passo 2, immagine 1 di 2 Disassembling Toshiba NB205 N330PK Back Panels: passo 2, immagine 2 di 2
    • To replace the panel, do step 1 in reverse:
    • Align the panel slots in the appropriate grooves and set in place.
    • With the bit driver, replace the screw to secure the RAM panel.
  3. Disassembling Toshiba NB205 N330PK Back Panels: passo 3, immagine 1 di 2 Disassembling Toshiba NB205 N330PK Back Panels: passo 3, immagine 2 di 2
    • Using the bit driver and the Phillips bit, remove both of the panel's retaining screws.
    • With the screws removed, lift the panel in the designated direction, as depicted in photo, for removal.
    • The hard drive is located beneath this cover and is now accessible.
  4. Disassembling Toshiba NB205 N330PK Back Panels: passo 4, immagine 1 di 2 Disassembling Toshiba NB205 N330PK Back Panels: passo 4, immagine 2 di 2
    • To replace the hard drive panel, do step 3 in reverse:
    • Place the panel back in its original position and press down.
    • If the hard drive was removed or replaced during this process, improper installation may prevent the hard drive panel from sitting in the slots properly.
    • With the bit driver and Phillips bit, replace the two retaining screws to secure the cover plate in place.
Conclusione
Mason McCaskill
Membro da: 10/18/13
1.000 Reputazione
9 Guide realizzate
Clemson, Team 14-2, Benson Fall 2013 Membro di Clemson, Team 14-2, Benson Fall 2013
CLEM-BENSON-F13S14G2
3 Membri
27 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 961
