Salta al contenuto principale
Disassembling Sony Vaio VGN-FW 590 Audio USB Board
Cosa ti serve
  1. Disassembling Sony Vaio VGN-FW 590 Audio USB Board, Audio USB Board: passo 1, immagine 1 di 1
    • - Remove battery.
    • - Remove memory tray door (1 Screw).
    • - Remove hard drive door (1 Screw).
    • - Remove hard drive (3 Screws).
  2. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: passo 2, immagine 1 di 1
    • - Remove all screws from the bottom cover. There are three types of screws. Marked here with Red Circles, Red Squares and Orange Circles.
  3. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: passo 3, immagine 1 di 1
    • - Remove CD/DVD Drive by sliding it out.
    • - Remove three more screws, which were hiding under the DVD drive.
  4. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: passo 4, immagine 1 di 1
    • - Carefully remove the cover, by unpopping it with a slim flathead, slide it out away from the RJ-45, HDMI and VGA ports.
  5. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: passo 5, immagine 1 di 1
    • - The audio/usb interface card is now within reach. Just remove the two screws and carefully slide out the flat connector to remove the card.
  6. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: passo 6, immagine 1 di 1
    • - Fire up the air compressor and blow out dust from the fan and heatsinks.
  7. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: passo 7, immagine 1 di 1
    • - If you are replacing your RAM, simply unpop the four latches and slide out the memory sticks.
Conclusione
Altre 8 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 21,088
