Introduzione
This guide will explain how to take off the camera's exterior case.
Parti
Nessuna parte richiesta.
Begin by placing the camera upside down and removing the three small center screws.
  • Begin by placing the camera upside down and removing the three small center screws.
  • All screws are the same size and length and can be used interchangably.
Aggiungi Commento
Turn the camera on its side (Counterclockwise). Remove the two small screws on either side of the silver panel. Turn the camera 180 degrees onto its other side and remove the two small screws on either side of the silver panel.
  • Turn the camera on its side (Counterclockwise). Remove the two small screws on either side of the silver panel.
  • Turn the camera 180 degrees onto its other side and remove the two small screws on either side of the silver panel.
Aggiungi Commento
Locate the camera's tripod mount located on the bottom of the camera. Carefully remove the camera's tripod mount and place it aside. Be careful not to lose this piece.
  • Locate the camera's tripod mount located on the bottom of the camera.
  • Carefully remove the camera's tripod mount and place it aside.
  • Be careful not to lose this piece.
  • Rotate the silver panel labeled 4x clockwise.
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Alex
Membro da: 09/03/2012
172 Reputazione
3 Guide realizzate
Clemson, Team 2-3, Benson Spring 2012 Membro di Clemson, Team 2-3, Benson Spring 2012
CLEM-BENSON-S12S2G3
3 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,278
