Parti
Nessuna parte richiesta.
Start here with your Clie in hand.
  • Start here with your Clie in hand.
Aggiungi Commento
Unlock the cover slide lock.
  • Unlock the cover slide lock.
Aggiungi Commento
Remove cover.
  • Remove cover.
Aggiungi Commento
Remove the six case screws on the sides and bottom of the device.
  • Remove the six case screws on the sides and bottom of the device.
Aggiungi Commento
Remove the front case.
  • Remove the front case.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Turn the device over and remove the back case.
  • Turn the device over and remove the back case.
Aggiungi Commento
Allow room for the case to come off from the scrool wheel.
  • Allow room for the case to come off from the scrool wheel.
Aggiungi Commento
Remove the two screws holding the scroll wheel in place.
  • Remove the two screws holding the scroll wheel in place.
Aggiungi Commento
Pull out both sides of the clip to remove the scroll wheel power cable from the device.
  • Pull out both sides of the clip to remove the scroll wheel power cable from the device.
Aggiungi Commento
Unscrew the two screws to remove the battery harness.
  • Unscrew the two screws to remove the battery harness.
Aggiungi Commento
Pull the power cable from the socket.
  • Pull the power cable from the socket.
Aggiungi Commento
Pull out the clips to remove the power cables from the motherboard.
  • Pull out the clips to remove the power cables from the motherboard.
Aggiungi Commento
Rotate the motherboard toward you to expose the power cables on the other side.
  • Rotate the motherboard toward you to expose the power cables on the other side.
Aggiungi Commento
Aggiungi Commento
Conclusione
Steve
Membro da: 18/10/2011
1 Reputazione
1 Guida realizzata
James Madison, Team 1-4, Allen Fall 2011 Membro di James Madison, Team 1-4, Allen Fall 2011
JMU-ALLEN-F11S1G4
3 Membri
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,284
