Parti
Nessuna parte richiesta.
Remove the battery (which also functions as the back cover) from the device. This step is not explicitly shown, but a picture without the battery cover shows the device post-battery removal. Remove the battery (which also functions as the back cover) from the device. This step is not explicitly shown, but a picture without the battery cover shows the device post-battery removal.
  • Remove the battery (which also functions as the back cover) from the device. This step is not explicitly shown, but a picture without the battery cover shows the device post-battery removal.
Aggiungi Commento
Use a Philip's head screw driver to remove the screws from the case. Place the screws in a small container to avoid losing them.
  • Use a Philip's head screw driver to remove the screws from the case.
  • Place the screws in a small container to avoid losing them.
Aggiungi Commento
Remove the front cover. First, insert a small pry bar where the black front cover and white back cover meet. Begin prying the black plastic up, slowing moving around to the bottom and other side.
  • Remove the front cover.
    • First, insert a small pry bar where the black front cover and white back cover meet.
    • Begin prying the black plastic up, slowing moving around to the bottom and other side.
    • At an angle, carefully pull up on the front cover separate the two pieces.
  • Excellent! Now you have removed the front cover!
Aggiungi Commento
While looking down at the device, place your index finger at the top of the circuit board and your thumb on the device screen.
  • While looking down at the device, place your index finger at the top of the circuit board and your thumb on the device screen.
Aggiungi Commento
Using your fingers, gently pull the top of the circuit board up toward you while also sliding the bottom of the circuit board away from the bottom of the Sirius Stiletto 100 back cover. Using your fingers, gently pull the top of the circuit board up toward you while also sliding the bottom of the circuit board away from the bottom of the Sirius Stiletto 100 back cover.
  • Using your fingers, gently pull the top of the circuit board up toward you while also sliding the bottom of the circuit board away from the bottom of the Sirius Stiletto 100 back cover.
Aggiungi Commento
Congratulations! You have successfully removed the internal circuit board from the Sirius Stiletto 100 back cover.
  • Congratulations! You have successfully removed the internal circuit board from the Sirius Stiletto 100 back cover.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Staten
Membro da: 09/03/2012
69 Reputazione
1 Guida realizzata
Clemson, Team 2-1, Benson Spring 2012 Membro di Clemson, Team 2-1, Benson Spring 2012
CLEM-BENSON-S12S2G1
3 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,717
