Introduzione
This guide illustrates how to remove the battery from a Sanyo Katana Eclipse X.
Parti
Nessuna parte richiesta.
Press the battery release button located on the back of the phone. With the button depressed, pull down on the battery protector to remove it from the phone.
  • Press the battery release button located on the back of the phone.
  • With the button depressed, pull down on the battery protector to remove it from the phone.
    • The phone's battery will now be exposed.
Aggiungi Commento
Slide a thin object under the white tab located on the bottom of the battery and carefully lift away from the phone.
  • Slide a thin object under the white tab located on the bottom of the battery and carefully lift away from the phone.
    • A small, flat-tip screwdriver or credit card may be helpful for this step.
  • The battery should now be free of the phone.
Aggiungi Commento
Conclusione
Thomas Scaggs
Membro da: 15/10/2012
209 Reputazione
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 155
