Salta al contenuto principale
Disassembling Samsung TFT Color YP-T7J Removing the Front Cover
Cosa ti serve
  1. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover, The Back Cover: passo 1, immagine 1 di 2 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover, The Back Cover: passo 1, immagine 2 di 2
    • Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
  2. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: passo 2, immagine 1 di 2 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: passo 2, immagine 2 di 2
    • Remove the screw on each side of the device using a Phillips head screwdriver.
  3. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: passo 3, immagine 1 di 3 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: passo 3, immagine 2 di 3 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: passo 3, immagine 3 di 3
    • Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws.
    • Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
  4. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover, The Front Cover: passo 4, immagine 1 di 2 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover, The Front Cover: passo 4, immagine 2 di 2
    • Using the philips screwdriver, remove the two screws on the mother board.
  5. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: passo 5, immagine 1 di 3 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: passo 5, immagine 2 di 3 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: passo 5, immagine 3 di 3
    • Place the pry tool in-between the front cover and mother board.
    • Gently separate the front cover.
  6. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: passo 6, immagine 1 di 1
    • After opening the front cover you will see and electric ribbon connecting the buttons to the mother board.
  7. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: passo 7, immagine 1 di 2 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: passo 7, immagine 2 di 2
    • CAUTION: Do not rip the electric ribbon from the mother board.
    • Carefully flip up the plastic lip that holds the electric ribbon to the board.
Conclusione
Jason Farr
Membro da: 10/21/13
353 Reputazione
3 Guide realizzate
Clemson, Team 14-8, Benson Fall 2013 Membro di Clemson, Team 14-8, Benson Fall 2013
CLEM-BENSON-F13S14G8
3 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 242
