Introduzione
How to remove all speakers on the phone.
Push open the latch and remove the battery. Push open the latch and remove the battery.
  • Push open the latch and remove the battery.
Aggiungi Commento
Twist off the antenna. Pop off the transparent cylinder.
  • Twist off the antenna.
  • Pop off the transparent cylinder.
Aggiungi Commento
Remove the five screws as shown.
  • Remove the five screws as shown.
Aggiungi Commento
Carefully pry the back plate off.
  • Carefully pry the back plate off.
Aggiungi Commento
Carefully detach golden screen connector. Carefully detach golden screen connector.
  • Carefully detach golden screen connector.
Aggiungi Commento
Pop out the logic board with spudger. Caution: Do not touch with bare hands, use tweezers or wash hands before contact.
  • Pop out the logic board with spudger.
  • Caution: Do not touch with bare hands, use tweezers or wash hands before contact.
Aggiungi Commento
Place the logic board on a clean tray. Place the logic board on a clean tray.
  • Place the logic board on a clean tray.
Aggiungi Commento
Remove the hinge on the phone. Put pressure on the spring with the screwdriver to unhinge phone.
  • Remove the hinge on the phone.
    • Put pressure on the spring with the screwdriver to unhinge phone.
  • Make sure to pull the gold wire through, don't let it rip.
Aggiungi Commento
Remove the four screws as shown Use the spudger to pry it open, excessive force may be necessary. Use the spudger to pry it open, excessive force may be necessary.
  • Remove the four screws as shown
  • Use the spudger to pry it open, excessive force may be necessary.
Aggiungi Commento
Remove the three screws that hold the big speaker Caution: The wires are attached to the screen and should be removed with care. Caution: The wires are attached to the screen and should be removed with care.
  • Remove the three screws that hold the big speaker
    • Caution: The wires are attached to the screen and should be removed with care.
Aggiungi Commento
Conclusione
doconnor
Membro da: 19/04/2010
25 Reputazione
12 Guide realizzate
Cal Poly, Team 10-43, Garner Spring 2010 Membro di Cal Poly, Team 10-43, Garner Spring 2010
CPSU-GARNER-S10S10G43
5 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,830
