Introduzione
This guide tells you how to remove the back or rear panel of the Samsung Epic 4G, which is an important first step in working with the internal parts of the phone.
Parti
Nessuna parte richiesta.
Turn off the phone using the "Power Button". The Power button is located on the left side of the phone and has a circle on it.
  • Turn off the phone using the "Power Button". The Power button is located on the left side of the phone and has a circle on it.
  • To remove the back panel of the phone, slide your fingernail along the edge of the device and pull at the panel as shown in the figure. While pulling at it along the edge you will hear a snap. That snap tells you that the panel is coming off the phone.
Aggiungi Commento
After hearing the snap you should be able to remove the plastic backing by pulling at it gently.
  • After hearing the snap you should be able to remove the plastic backing by pulling at it gently.
Aggiungi Commento
Linea Traguardo
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 24-25, Regan Fall 2012 Membro di Cal Poly, Team 24-25, Regan Fall 2012
CPSU-REGAN-F12S24G25
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 730
