Introduzione
This guide is to remove the base plate. This will allow you to access the rest of your saw and disassemble it properly.
Parti
Nessuna parte richiesta.
Orient your saw so that the blade is pointing in the opposite direction of your body. Ensure that the screws circled are visible and pointing skyward. This will be the standard position of the Jigsaw for the duration of this guide. Orient your saw so that the blade is pointing in the opposite direction of your body. Ensure that the screws circled are visible and pointing skyward. This will be the standard position of the Jigsaw for the duration of this guide. Orient your saw so that the blade is pointing in the opposite direction of your body. Ensure that the screws circled are visible and pointing skyward. This will be the standard position of the Jigsaw for the duration of this guide.
  • Orient your saw so that the blade is pointing in the opposite direction of your body. Ensure that the screws circled are visible and pointing skyward. This will be the standard position of the Jigsaw for the duration of this guide.
Aggiungi Commento
  • Using two hands grip both side of the saw and lift 90 degree as demonstrated.
Aggiungi Commento
  • Identify the screw circled in red and remove with Phillips screwdriver.
Aggiungi Commento
  • Lift base plate up into the air and place off to side. Do not forget to place the removed screw in an area you will easily find it later.
Aggiungi Commento
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,287
