Salta al contenuto principale
Disassembling RCA CC310 Left Cover
Cosa ti serve
  1. Disassembling RCA CC310 Left Cover, Disassembling RCA CC310 Left Cover: passo 1, immagine 1 di 2 Disassembling RCA CC310 Left Cover, Disassembling RCA CC310 Left Cover: passo 1, immagine 2 di 2
    • Remove the six 7.9mm Phillips #0 screws on the back and bottom.
    • Remove the one 3.8mm Phillips #0 screw on the bottom.
    • Remove the two 7.5mm Phillips #0 screws on the back and bottom.
  2. Disassembling RCA CC310 Left Cover: passo 2, immagine 1 di 2 Disassembling RCA CC310 Left Cover: passo 2, immagine 2 di 2
    • Remove 5.8mm Phillips #1 screw from the side button panel.
    • Slide the viewfinder all the way to the right and remove the 7.9mm Phillips #0 screw.
  3. Disassembling RCA CC310 Left Cover: passo 3, immagine 1 di 2 Disassembling RCA CC310 Left Cover: passo 3, immagine 2 di 2
    • Pry along the seam on the top side near the buttons with a spudger.
  4. Disassembling RCA CC310 Left Cover: passo 4, immagine 1 di 2 Disassembling RCA CC310 Left Cover: passo 4, immagine 2 di 2
    • Pull the left panel away from the rest of the camcorder.
    • Unplug the red speaker cable located at the rear of the device.
    • Be careful to not pull too hard. The speaker cable is still connected to the panel and it can rip.
Conclusione
Cal Poly, Team 5-20, Amido Winter 2011 Membro di Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 919
