Introduzione
The stand and back panel removal are the first steps to fixing anything in your TV.
Parti
Nessuna parte richiesta.
Before disassembling your television, ensure that all cables are unplugged from their power source to avoid serious injury or death from electrocution. Lay the TV flat with the screen facing down.
  • Before disassembling your television, ensure that all cables are unplugged from their power source to avoid serious injury or death from electrocution.
  • Lay the TV flat with the screen facing down.
  • Remove the four, 12mm Phillips #2 screws from the back of the TV stand. Support the TV from underneath as you remove the screws, so the bottom does not fall on the table.
  • Remove the stand by lifting it away from the TV's backing.
Aggiungi Commento
Remove the twelve, 6mm Phillips #2 screws from the middle of the TV's rear casing. Remove the seven, 9mm Phillips #2 screws from the outer edge of the TV's rear casing.
  • Remove the twelve, 6mm Phillips #2 screws from the middle of the TV's rear casing.
  • Remove the seven, 9mm Phillips #2 screws from the outer edge of the TV's rear casing.
  • While holding the screen down, pull the back panel up slowly, ensuring that you do not forcibly disconnect the remaining ribbon cable.
Aggiungi Commento
Position the television to where the back panel is resting on the table and the screen is vertical.
  • Position the television to where the back panel is resting on the table and the screen is vertical.
  • Peel the tape covering the ribbon cable horizontally.
Aggiungi Commento
Pinch the clamps on both sides of the ribbon cable casing to detach it from the screen panel. Remove the screen to isolate the back panel. Remove the screen to isolate the back panel.
  • Pinch the clamps on both sides of the ribbon cable casing to detach it from the screen panel.
  • Remove the screen to isolate the back panel.
Aggiungi Commento
Conclusione
Patrick Soper
Membro da: 15/01/2015
673 Reputazione
6 Guide realizzate
Cal Poly, Team 70-2, Forte Winter 2015 Membro di Cal Poly, Team 70-2, Forte Winter 2015
CPSU-FORTE-W15S70G2
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 419
