Introduzione
How to replace the LCD screen if it is broken or cracked.
Parti
Nessuna parte richiesta.
Locate the battery cover on the bottom of the camera.
  • Locate the battery cover on the bottom of the camera.
Aggiungi Commento
Place your thumb on the battery cover and push towards the arrow. The cover will release and pop open.
  • Place your thumb on the battery cover and push towards the arrow. The cover will release and pop open.
Aggiungi Commento
Remove the batteries from the camera.
  • Remove the batteries from the camera.
Aggiungi Commento
Unscrew and remove four (3mm) screws on the right side of the camera. This will release the front and back casings.
  • Unscrew and remove four (3mm) screws on the right side of the camera. This will release the front and back casings.
Aggiungi Commento
Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
  • Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
  • Repeat this step for the back casing.
Aggiungi Commento
Locate the black plastic strip under the screen above the white plastic strip.
  • Locate the black plastic strip under the screen above the white plastic strip.
Aggiungi Commento
Pull up both sides of the black piece up about a mm.
  • Pull up both sides of the black piece up about a mm.
  • The black plastic piece is not meant to come all the way off, just enough to release the screen.
  • Once the piece is lifted carefully slide the screen out of the slot.
Aggiungi Commento
Conclusione
Dani
Membro da: 24/06/2010
21 Reputazione
7 Guide realizzate
Cal Poly, Team 3-3, Johann Summer 2010 Membro di Cal Poly, Team 3-3, Johann Summer 2010
CPSU-JOHANN-R10S3G3
2 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,515
