Salta al contenuto principale
Disassembling Philips Portable Speaker SBA1610 37 Battery Casing
Cosa ti serve
  1. Disassembling Philips Portable Speaker SBA1610 37 Battery Casing, Battery Casing: passo 1, immagine 1 di 1
    • Remove the back cover by sliding it off.
    • Remove the 3 AAA batteries.
  2. Disassembling Philips Portable Speaker SBA1610 37 Battery Casing: passo 2, immagine 1 di 3 Disassembling Philips Portable Speaker SBA1610 37 Battery Casing: passo 2, immagine 2 di 3 Disassembling Philips Portable Speaker SBA1610 37 Battery Casing: passo 2, immagine 3 di 3
    • Unscrew the nine exterior screws on the back panel using a PH0-size Philips-head screwdriver.
    • A larger screwdriver head and more force may be required for damaged screws.
    • Remove the triangular end piece by pulling it straight off.
  3. Disassembling Philips Portable Speaker SBA1610 37 Battery Casing: passo 3, immagine 1 di 2 Disassembling Philips Portable Speaker SBA1610 37 Battery Casing: passo 3, immagine 2 di 2
    • Remove the colored grill by sliding it off in the direction of the removed end piece.
    • Pry off the back battery panel with the plastic opening tool.
    • Be careful to avoid tearing any wires.
Conclusione
Clemson, Team 14-4, Benson Fall 2013 Membro di Clemson, Team 14-4, Benson Fall 2013
CLEM-BENSON-F13S14G4
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 4,701
