Introduzione
Since this is step one, you will just need to start with your camera.
Parti
Nessuna parte richiesta.
Remove the battery and memory card from the device.
  • Remove the battery and memory card from the device.
Aggiungi Commento
Remove 4 screws from the right side of the camera.
  • Remove 4 screws from the right side of the camera.
    • There are two 3.4mm screws at the top.
    • There are two 2.2mm screws at the bottom.
Aggiungi Commento
Remove the single 3.4mm screw on the left side of the camera.
  • Remove the single 3.4mm screw on the left side of the camera.
Aggiungi Commento
Remove 5 screws from the base of the camera.
  • Remove 5 screws from the base of the camera.
    • There are two 2.2mm screws next to the battery compartment.
    • There are three 4mm screws around the tripod mount.
Aggiungi Commento
Slowly slide the back cover away from the device
  • Slowly slide the back cover away from the device
    • The back casing is held in place by two ribbon cables. Do not pull the back cover too far from the camera.
Aggiungi Commento
Detach both ribbon cables using a spudger. Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
  • Detach both ribbon cables using a spudger.
    • Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
Aggiungi Commento
Remove the back casing from the camera.
  • Remove the back casing from the camera.
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Ben Canfield
Membro da: 10/10/2010
391 Reputazione
3 Guide realizzate
Cal Poly, Team 9-21, Regan Fall 2010 Membro di Cal Poly, Team 9-21, Regan Fall 2010
CPSU-REGAN-F10S9G21
4 Membri
7 Guide realizzate
That is not a disassembly! All is shows is taking the back of the camera off. How about showing how to disassembly the camera down to its individual components and make repairs, like getting the lens to extend of fixing a sticking shutter.
JR Tan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 24
Tutti i Tempi: 5,892
