Remove the four rubber screw covers from encircled locations.
  • Remove the four rubber screw covers from encircled locations.
  • Using a #0 tri wing screwdriver, remove the screws previously hidden below the rubber covers.
  • If you have difficulties finding this screwdriver, it is commonly sold as a Nintendo Gameboy/Wii screwdriver.
Aggiungi Commento
Pry the case open using iPhone tool (as shown), fingernails, small flathead screwdriver, etc.
  • Pry the case open using iPhone tool (as shown), fingernails, small flathead screwdriver, etc.
  • Be mindful of location and magnitude of applied force, so as not to damage the case.
Aggiungi Commento
Unlock the minor LCD connector by applying bilateral pressure with tweezers, as shown.
  • Unlock the minor LCD connector by applying bilateral pressure with tweezers, as shown.
Aggiungi Commento
Use fingernails to pry off minor LCD mount, as shown.
  • Use fingernails to pry off minor LCD mount, as shown.
  • Remove the minor LCD
Aggiungi Commento
Unlock the LCD main board connectors shown in red boxes on the picture .
  • Unlock the LCD main board connectors shown in red boxes on the picture .
  • Use tweezers as necessary.
Aggiungi Commento
Place finger nails on the connector tab as shown.
  • Place finger nails on the connector tab as shown.
  • Lift the connector tab up.
Aggiungi Commento
Pull/pivot the LCD main board as shown in order to remove.
  • Pull/pivot the LCD main board as shown in order to remove.
Aggiungi Commento
Conclusione
Van
Membro da: 24/06/2010
7 Reputazione
16 Guide realizzate
Cal Poly, Team 2-10, Johann Summer 2010 Membro di Cal Poly, Team 2-10, Johann Summer 2010
CPSU-JOHANN-R10S2G10
4 Membri
20 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,729
