Salta al contenuto principale
Disassembling Optoma HD20 Cover
Cosa ti serve
  1. Disassembling Optoma HD20 Cover, Disassembling Optoma HD20 Cover: passo 1, immagine 1 di 2 Disassembling Optoma HD20 Cover, Disassembling Optoma HD20 Cover: passo 1, immagine 2 di 2
    • Twist the focal cap clockwise until it is fully extended.
    • Remove the focal cap by pulling it straight out.
  2. Disassembling Optoma HD20 Cover: passo 2, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
  3. Disassembling Optoma HD20 Cover: passo 3, immagine 1 di 1
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
  4. Disassembling Optoma HD20 Cover: passo 4, immagine 1 di 1
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
Conclusione
Altre 8 persone hanno completato questa guida.
Trever
Membro da: 01/22/15
1.264 Reputazione
6 Guide realizzate
Cal Poly, Team 21-23, Maness Winter 2015 Membro di Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 18
Tutti i Tempi: 3,043
